Author Topic: Anti seize grease/paste  (Read 1537 times)
  • Auckland
    • Mazda MPV
« on: 12 July 2015, 22:25:09 »
Any recommendations?
I have been using copper grease for years on exhaust bolts and it works but it leaves a filthy mess. It also works  on threads exposed to water/coolant but I don't think it has any anti-corrosion properties :-\
Does any one know of anything better/newer/cleaner?
I have spent 2 days undoing masses of partially seized nuts to get the turbo off SWMBO's Galaxy. The job should have taken 2 hours (allegedly).
I will definitely be putting something on all the threads to stop them seizing again but I think there must be something cleaner than copper grease :-\
Crazycarzowner
Re: Anti seize grease/paste
« Reply #1 on: 12 July 2015, 22:34:50 »
You have my sympathies there mate  ::) ::) ::) I've been exactly the same with the Disco suspension.
I've used this stuff Locktite Anti-seize copper http://www.halfords.com/motoring-travel/engine-oils-fluids/lubricating-penetrating-oil/loctite-anti-seize-copper-lubricant-20g
Not cheap but does what it says.....  :-\ :-\ :-\
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #2 on: 12 July 2015, 23:15:56 »
Copper grease is the tool for the job.
If it leaves a filthy mess, you're using far too much! A smear on the end of a manifold stud, which the nut will carry down the thread as you tighten it, is plenty. A cheap disposable brush is the best way to apply it.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #3 on: 12 July 2015, 23:23:10 »
I just dip the end of a bolt/stud into the tub and allow it to 'flow' down the thread. No mess. No need for paint brushes.
The only time i get it on my finger is when applying it to the back of brake pads, and thats only a smear.  Comes out in the wash!  ::)
