Author Topic: Disco electrics problem doin me head in!!!  (Read 6537 times)
Re: Disco electrics problem doin me head in!!!
« Reply #15 on: 13 July 2015, 21:17:30 »
My immediate thoughts were the starter solenoid............. :-\
  • Auckland
    • Mazda MPV
« Reply #16 on: 13 July 2015, 21:28:05 »
No as far as I'm aware its not been off road, as a matter of fact its not been anywhere really. Prior to me buying it this time last year it was off road stuck in a barn for the best part of 5 years and I've only used it occasionally over the last year (about 1000 miles).
Haha henryd  ;D ;D ;D Yup mine is the petrol gulping V8 soon to be LPG'd  :y
Thanks for the replies guys, this site is a lot better than the Discovery site I'm PAYING to be a member of. You can put post up there and they have cobwebs on them before they get read & replied to  :y :y :y
Gonna start with the starter relays in the am if it ain't too wet tomoz and take it from there.
It doesn't have to get muddy to have the problem - a light coating of rust due to not being used much could also cause the solenoid to struggle to fire the pinion into the ring gear.
Crazycarzowner
« Reply #17 on: 13 July 2015, 21:36:53 »
Ah! righty ho Andy, I'll add that to the list of things to check  :y
the alarming man
  • medway kent
    • disco V8
« Reply #18 on: 13 July 2015, 21:37:24 »
nope deffo ignition switch it is a known fault
Crazycarzowner
« Reply #19 on: 13 July 2015, 21:39:51 »
Could you elaborate anymore on that Mr Alarming man please???
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #20 on: 13 July 2015, 21:48:51 »
Ignition switch on the back of the barrel wears out, had 2 go on me ( not on lamdies mind)and the symptoms baffled the AA , garages etc. I had position 1+2 with the dash lights coming on then break all when trying to start it, happened randomly. Switch is easy to change usually and about a tenner so worth bearing in mind if your going to start swapping stuff
« Reply #21 on: 13 July 2015, 21:53:11 »
I'd be starting at the ignition switch and working down the line :y
Should have a ground, constant and switched live... I reckon the delay is the (internal) contacts for the switched live being knackered. I think I had the same on my RR at one point :-\
Crazycarzowner
« Reply #22 on: 13 July 2015, 21:59:36 »
Cheers guys!!!!
« Reply #23 on: 13 July 2015, 22:01:55 »
Just to add... It should have a switched live (act position) and a live that switches with cranking to fire the relay for the starter, IIRC
« Reply #24 on: 13 July 2015, 22:26:22 »
Range Rover or Rolls Royce? Just checking how well business is going ;) ;D
(But yes, I'd start with the switch and work my way down to the starter .. start with the easy bits and work your way to the oily bits!)
« Reply #25 on: 13 July 2015, 23:20:01 »
The latter of course ::) ::)
Business is slow but steady... Considering expanding into the Reading area (I think it basically runs from A34 to M25, M3 to M40. But they have to do me a good deal  ;)
Crazycarzowner
« Reply #26 on: 14 July 2015, 14:48:44 »
Well guys, this am I swapped over the ignition switch for a known good one & still the problem persists  :'( So then off comes the drivers side kick panel under the dash. Swapped out the starter relay, still same problem  :'( :'( :'(
Next thing to try when I've time is the starter motor  :-\ ???
« Reply #27 on: 14 July 2015, 14:52:33 »
Have you done the electrical tests? Check it is actually switching? As above, it's a common failure
Crazycarzowner
« Reply #28 on: 14 July 2015, 15:35:00 »
Took the switch out and replaced it with a known working one, plugged the other one in & tried to start it - same problem.   :-\ :-\ :-\
« Reply #29 on: 14 July 2015, 15:36:56 »
Find the cranking live and see if it switches immediately, then you can guarantee it is ok. Just to be certain
