Be afraid, be very afraid...
Started by 05omegav6, 16 July 2015, 08:05:56
OFJ Connections, openly known as One F ing Joke, took over the Gatwick Staff Bus contract on Tuesday night.
So far I have endured two journeys with them... t
On the first trip, the driver forced a cyclist off a roundabout and onto the verge, pulled from a bus lane into a busy traffic lane without indicating or looking causing two cars to brake/swerve and mounted a six inch kerb whilst negotiating a junction at speed. He was also unable to brake to a stop with anything approaching finesse or even anticipation... panic braking from 40+ (in a 30 limit) having failed to notice a mini roundabout just one example.
This mornings' driver was better, but only because he didn't hit anything/one... the rest of his driving was just as horrific.
Airlinks, part of National Express, were far from perfect... speeding being their biggest issue, but the drivers did at least know how to stop the bus without sending people flying down the aisle.
Apparently OFJ have had their first significant smash already, less than 36 hours in, with a driver overshooting a junction and posting a bus. Only a matter of time before the actually kill someone :-\
Have fired off a complaint to Gatwick Airport Ltd, but will start filming trips just in case...
Gaffers
Quote from: Harris K Telemacher on 16 July 2015, 08:05:56
... but will start filming trips just in case...
IMO the only way to get the Police to take any notice (as many cyclists are already well aware)
I doubt that Gatwick will do the square root of fleck all if you send it to them.  Post it on Youtube, get it viral and then, and only then, will plod actually do something.
(Not a reflection on the quality of any plod members on here, just my perception based on my experiences)
biggriffin
#2
Apparently OFJ have had their m significant smash already, less than 36 hours in, with a driver overshooting a junction and posting a bus. Only a matter of time before the actually kill someone :-\
From the above description, the driver seems a very professional, bus driver who was trained by the standard bus training association who train all bus drivers.obviously not up to oof A1 driving standards then.
Bus drivers round here use the throttle pedal and brake pedals like switches On and off,and as for indicating, they don't work,.
Hoof'land storeman.
Or my mother has taken a retirement job without telling me, as that's been her driving 'technique' for years.
Filmed the journey in last night and the return this morning... last night was ok apart from poor anticipation.
Ignoring running over a kerb on a roundabout having pulled out right in front of a car, this mornings journey wasn't too bad... once the driver clocked that he was being filmed ::)
He was driving like a twot once I got off the bus though, presumably trying to make up for driving at a sensible pace...
I assume this is a park and ride to work?
If so, all the passengers need to make constant complaints... They have a duty of care if they are providing it ;)
They are being inundated with complaints...
Driver tonight was the same one as first journey, and still as horrendous. He got quite vocal when I suggested that he retook his test, waving his arms and everything :D
Unfortunately due to memory issues I was unable to film the whole journey...
Quote from: Harris K Telemacher on 17 July 2015, 20:00:07
Happens when you get to a certain age .. I find writing myself reminder notes helps ....   :y :y ;) ;)
;D ;D ;D ;D
Quote from: Entwood on 17 July 2015, 20:11:58
;D ;D ;D ;D
:D :D :D
;D ;D ;D ;D
Writing notes is easy :) remembering that you have written a note is the hard part  ::)
Not so much what you wrote on the note, but rather what you wrote the note on... :-[
;D
biggriffin
#11
He's a bus driver FFS, you obviously haven't used public transport for a long time. They have a schedule to keep,and passengers interfere with that. Also he isn't a perfect Oof trained driver.
Also you want to go on the freight shuttle buses down at euro-tunnel. They don't give a freck. Ive never seen a mini-bus go as fast in such a short run,and not slow down, its like a ride at Alton towers.
Hoof'land storeman.
chrisgixer
Seen similar on the M4 with Horseman coaches and National express. Employ a retard and let him loose in charge of a bus full of people. Madness.
I suspect the worst drivers are taught, and significantly,  tested in house by London bus companies...
This is not good.
Quote from: Harris K Telemacher on 18 July 2015, 18:03:39
This is not good.
Basically, if you are trained and tested in house, then your licence should be tied to that company... If you move or the company changes hands, you should be recertified.
If your licence was acquired independently, then you will likely be trained and tested to a higher standard... In theory.
