Fuel
Started by badmuver, 16 July 2015, 16:54:53
badmuver
I'm off the Scotland soon  ;D. what is the best fuel (unleaded) for best millage  :-\.
mka306
The stuff that comes out of the unleaded pump is a good start  ;D ;D ;D
badmuver
 ;D
Quote from: mka306 on 16 July 2015, 16:58:53
zirk
If your going on a long run and can afford it, stick some Super Unleaded in there, you should get a tad more mpg or worse case it will give the fuel system a clean.
If your a Shell Drivers Club fan, there currently doing a Super Unleaded promotion at the moment, fill up more than 4 times of the stuff (min fill 20 litres each one) and you get an extra 1000 points on top of your Drivers Card.  :y
Broomies Mate
IME the 4 pots respond well to the higher octane fuels, and the V6 doesn't.  Must be something to do with the way the ECU adapts.  :-\
biggriffin
I have used 99',octane, shell super and Bp super, no noticeable improvement in mpg whatsoever, upon stripping an engine that had spent most of its life run on super 99, the combustion chambers and exhaust tracts and pistons were very clean,
You just get a better burn, which means bit more power,not very detectable unless its on a dyno or rolling rd.
is it worth the 8/10p a litre more,
Hoof'land storeman.
Broomies Mate
I get the best results from Tesco's Finest ®  But this engine was designed for >98 octane.
I find Tesco Fuel to be consistently good.  Esso, per chance?  :-\
Phil L
Quote from: biggriffin on 16 July 2015, 21:05:47
I personally think not
Wishing I'd not sold the 67 Mustang...
I have just filled up with some super dooper diesel, awaiting results........... :-\ :-\
Quote from: Phil L on 16 July 2015, 21:25:05
Think not or know not?
I find it makes the engine more resposive, and pressing on requires a bit less effort, but that in turn leads to using more throttle more of the time... the noise of the 3.2 as the revs climb is addictive :-[
The extra mpg paid for itself in my 1.4 106 XSi which I used to rag the living daylights out of... the differences in performance in the Omega will obviously be less noticeable as it weighs almost three times as much ::)
Because I only use bike for commuting these days, 95 goes in.
The times I used ultimate or similar, I can really feel the difference. Much more pick up and go, smoother too as mentioned above.
Better on fuel too, although not enough to justify the extra cost. So it only goes in on tours or fun rides  8)
