oil spill
Started by pauls, 18 July 2015, 14:37:40
pauls
Any quick easy ways to get autobox fluid off the drive. I was going to jetwash it with a bit off degreaser but i thing that will just make a mess
I used Gunk's Pathclear to clean oil from my drive ..... works pretty well & doesn't make a mess  :y
http://www.halfords.com/motoring-travel/engine-oils-fluids/engine-cleaner-degreaser/gunk-driveway-clear-1l
Webby the Bear
if theres a big pool of it (been there done that  ::)) put loads of cat litter on it to absorb most of it. sweep it up. throw away
then use the stuff andy posted.
if theres not a ''pool'' just go straight with the gunk  :y
RIP Paul Lovejoy
Yep, Gunk is still the best, don't need posh pathclear, just Gunk will do........... :y :y
OK just looked online, Gunk seems to have gone post and specialised, so yes, go for the pathclear, things have moved on since I did my drive in 1985............ ::) ::) :-[
Daz Automatic washing powder is pretty good for fuel... But for some reason, it must be Daz :-\
Needs a bit of elbow grease too ;)
Quote from: Lazydocker on 19 July 2015, 02:29:29
Interesting..... :y We only use Daz............. :y :y
Quote from: Vamps on 19 July 2015, 02:47:44
Use the force..............
Quote from: Andy H on 19 July 2015, 08:00:50
No... Water and elbow grease  ;) :D
Seriously though... Sprinkle on, very small amount of water and scrub with a stiff brush... Rise and repeat as needed :y
Don't know about ATF though
tigers_gonads
Lidl's cheepo special does the trick too  :y
Hot water out of the kettle first.
A nice sprinkling of magic powder and a good scrub with a hard hand brush.
Rinse off with a touch more of boiling water then blast the bugger with the jet wash to get rid of he rest  :y
powerslinky
Down here in Saffend  we use Fug . . . so if Daz don't shift it  . . . FUG it !   ;D ;D ;D
Bigron
Not often I larf out loud, Al!!!   :y
;D ;D ;D ;D ;D
Ron.
the alarming man
cola works very well to  :y
Webby the Bear
Quote from: the alarming man on 19 July 2015, 19:55:01
does it?
I tried once to clean a battery with cola and it didn't work... apparently my yank mrs at the time said its cos theamerican recipe is different and that's the one that does work  :-\
RIP Paul Lovejoy
the alarming man
I don't know about that but apparently you pour it on and using a brush give it a scrub then wash off
Varche
Quote from: Webby the Bear on 19 July 2015, 20:07:05
does it?
EH? The mind boggules. Does your yank mrs of today concur? ;D ;D ;D
