Limo tint
Started by EMD, 18 July 2015, 18:56:35
EMD
Quote from: Webby the Bear on 18 July 2015, 21:10:47
steve, just as I post up a rude boy thread I stumble across this  ::) ::) ::) ::) :-X :-X :-X ;D
Its wicked innit  ;D 30mm spacers on the back next  :-X
Omegatitis
EMD
Stupid tint , got it perfect cut then torn off the backing film and the wind blew it onto itself
Omegatitis
Broomies Mate
If applying tint, use plenty of water with a SMALL dash of washing up liquid.  You need to 'float' the film to the glass.  I tend to use a spreader card (used for adding filler to body panels) wrapped in felt to 'push', the bubble from the middle out.  A sharp scalpel is a must also.
EMD
Heat gunned just like they showed in utube ... burnt it at the last minute  ::)
Persisted and just cut to shape then trimmed and heated ..
Both rears and quarters done , just the back screen to do which Will be fun im  sure  :-[
I wouldn't volunteer to do anybodys after this  :'(
Omegatitis
deviator
If you've never seen Mighty Car Mods, here is a good introduction....
https://www.youtube.com/watch?v=P2-b763DTpY
EMD
The rear window has a deep curve and the tint wont
react to heat shrink in the proper manor , the pleets wont shrink out  :(
I think its because the tint is not supple enough so you end up either melting
it or creasing it ..
Wonder how much they charge for doing just a rear window  ;D
Omegatitis
r1
Quote from: EMD on 23 July 2015, 12:12:34
a good place near me quoted 200 pounds for limo tint
says its a hard job as the rear shelf dosnt come out
Broomies Mate
Quote from: r1 on 23 July 2015, 21:54:39
Say what now?  :o
Take the shelf out yourself (Ten minutes) and say to them "TA-DAAAAA"....
Or use a tinting firm who know what they are doing.
Modern films have a 'memory'.  Use the exterior of the glass to 'shape' the film and then apply it in the normal way to the interior of the window.
S'not rocket!
EMD
Rear screen was a total failure  ::) The tint is in a ball in the bin now  >:(
Could not get the creasing out no matter what i tried , Will have to buy Omega
estate with flatter back screen  ::)
Omegatitis
biggriffin
#24
Quote from: EMD on 24 July 2015, 09:35:30
They are curved aswell. :)
Got a estate bodyshell, ;)  :y
Hoof'land storeman.
Did say it's one for the professionals, they make it look so easy. It's worth it though  :y
https://www.dropbox.com/s/zp1qx1uiwc7kfu3/2015-07-19%2019.47.04.jpg?dl=0
EMD
Still got the rears tinted tunnie so looks like yours from the side  :)
Bg'n , not as curved as the saloon though  :(
Omegatitis
