Author Topic: Interior light problem  (Read 4305 times)
Stagecoach
  • Fontwell, West Sussex
« on: 19 July 2015, 09:00:01 »
Hi all and good morning. I have bought a pre loved 2002 CDX MV6 that has the problem. NONE of the inside lights work. I have checked ALL fuses etc and nothing. All bulbs are OK but no voltage getting to them. The door buttons work OK.
I was told that the ashtray was removed during fitting of LPG switch, and looking at it there are two wires cut, and the cig lighter does not work either. Otherwise all standard.
Any help/advice please.
Re: Interior light problem
« Reply #1 on: 24 July 2015, 21:29:00 »
Nobody have any suggestions for Stagecoach?  ???
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 24 July 2015, 22:16:53 »
Interior lights and cigee lighter on same fuse. That's my limit on this, ive a similar problem at moment, my fuse keeps blowing, but haven't done a check yet.
Hoof'land storeman.
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #3 on: 25 July 2015, 11:25:51 »
Is there really NO light from any bulb in the entire compartment or the boot?
Stagecoach
« Reply #4 on: 25 July 2015, 11:53:18 »
None whatsoever. Even rear courtesy lights !!!
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #5 on: 27 July 2015, 15:30:19 »
Everything else works fine? (except cig lighter, does neither work, including light?)
The interior light runs on 3 fuses it looks like
« Reply #6 on: 27 July 2015, 16:09:21 »
Do they work independently? Front and rear lights have an independent reading function... that said, if your car is ex police it won't have rear ones fitted, (easily retro fitted) and the front ones wiring could have been used for anything :-\
Stagecoach
« Reply #7 on: 27 July 2015, 17:18:25 »
Rear interior lights not working either. I have checked every fuse under the steering wheel. Would there be others ?
I see you are not far from me Harris ...
« Reply #8 on: 27 July 2015, 17:57:23 »
Just up the road in fact ;) got a bit of time off in early August, so could possibly pop down and have a look one evening... Haven't had a Burger king for ages ::)
Stagecoach
« Reply #9 on: 27 July 2015, 18:30:04 »
LOL. Look forward to it. My treat. :)
