Propane bottle / pikey van question
Started by tigers_gonads, 21 July 2015, 11:57:52
tigers_gonads
For the first time in about 5 years, i've remembered to take a bottle of gas down to the van so we don't have to spend a fortune on takeaways to eat  ::)
Picked up a 6kg bottle yesterday for 15 quid but can I hell as remember what size spanner I need to bolt the regulator on ?
Anybody help on this ??
Cheers "Nads"  :-*
zirk
Quote from: tigers_gonads on 21 July 2015, 11:57:52
Cheers "Nads"  :-*
30mm seems to ring a bell, but from memory different bottles makes can use different sizes so adjustable would fit the bill.
tigers_gonads
tigers_gonads
Quote from: zirk on 21 July 2015, 12:07:11
Cheers "Nads"  :-*
The bottle already has a tap on it
Just need to bolt the regulator on but I don't own a 30mm spanner so I don't think its that big  :-\
24mm rings a hazy bell  :-\
If not, i'll have to part with some sheckles and buy a adjustable  :(
zirk
Either that or a big spanner and make sure you've got loads of pennies or washers in your pocket.
tigers_gonads
Quote from: zirk on 21 July 2015, 12:14:16
Man after my own heart  :y ;D ;D
YZ250
The calor spanner for the 37mbar propane regulator (red) is indeed 30mm.  :y
Just measured mine across the flats. Just a reminder that it's a left hand thread.  ;) :y
Bigron
You can buy a stamped metal spanner from most gas retailers/caravan shops for not many pennies - some may even give you one gratis. Oh, and definitely left-hand thread, do not overtighten it as it has a rubber insert.
Ron.
tigers_gonads
As it happens, i've just found a 30mm spanner in my toolbox  :y
I'll take it and see what happens  :y
Cheers Lads  :)
minifreek
Change the fitting to Butane, no need for spanners then :y
D.I.L.L.I.G.A.F...
