Your automatic choice!
Started by Andy B, 22 July 2015, 13:15:59
Ah the fifties. :y
No six...seven...eight or even nine speed auto box back then. :y
deviator
Quote from: Doctor Opti on 22 July 2015, 14:49:59
Ah the fifties. :y
The variomatic was the answer to needing 58 auto gears these days.
zirk
Hmm, can't see it catching myself, quiet like the crunchy stick.
Heaven forbid that someone like Vauxhall would only supply a car with an Autobox.
Now, where did I park me 3.2.
BazaJT
As a sort of middle ground you could always have gone for a car fitted with a pre-selector box fitted.Similar/same system as they used to fit to buses-do they still do so?Had to ask that as I can't recall the last time I caught a bus!
SIR Philbutt
Good find that  :y
One thing I noticed was the foot control for main beam, always a better idea those. Only ever had one car with that and found it very usable,  even on a manual
Quote from: SIR Philbutt on 23 July 2015, 01:34:45
Good find that  :y
My first car, a MKIII Cortina, had a squeeezy bulb there for the screen wash (later changed), I found that I couldn't press that with my left foot without my right foot altering the throttle to some degree  ???
Shackeng
Good find that  :y
I quite agree, all my early cars had that, and I found it worked well. I suppose if a gearchange and lights dip were simultaneously required, this may have been irritating, but IIRC it was never a problem. I would certainly prefer one on my autos than the column stick. :y
Quote from: BazaJT on 22 July 2015, 19:41:30
I've often wondered why we didn't get electronically controlled pre-selector gearboxes, rather than VW's horrendously complex two-gearboxes-in one-case DSG to achieve a similar result. Especially as the biggest justification for such things is that it makes for gear changes that happen in milliseconds.
Quote from: Nick W on 23 July 2015, 10:12:49
I can't get my head round that either  ???
GastronomicKleptomaniac
Most city buses are auto - but theres rumours of semi autos coming back on the grounds of fuel economy...
