Engine change
Started by EMD, 28 July 2015, 19:52:30
EMD
How long does it take to swap an engine over on the omega , was thinking of dropping a 3.0 engine in the 2.6  :-\ Facilities available of course .
Omegatitis
3.2 would make more sense... Be plug and play with no need to swap the sensors and intake/throttle gubbins/manifolds ;)
EMD
Quote from: Harris K Telemacher on 28 July 2015, 20:18:00
Hmm
Just wondering if it would be cheaper to sell the 2.6 and go for a 3.0 or 3.2 .. must be a day or 2 work to replace an engine and that will add up  :-\
Omegatitis
biggriffin
#3
Days work, including tea stops :)
3.0L into a 2.6 only thing to check is make sure 3.0L has late spec heads with holes for coil pack bolts. :)
Hoof'land storeman.
EMD
Quote from: biggriffin on 29 July 2015, 21:23:12
Half a day for serek then. Price would be the thing though  :-\
Omegatitis
biggriffin
Quote from: EMD on 29 July 2015, 21:36:22
I haven't got a ramp. ;)
Hoof'land storeman.
swordfish
          YOUR IN BOX IS  FULL  :y :y
EMD
Quote from: swordfish on 29 July 2015, 22:24:36
Sorted  :y
Omegatitis
Make sure it comes with the heads and manifolds still attached :-X
3.2 is still the easiest route :y
EMD
Im guessing that the brakes need upgrading too if a 3.2 is put in :-\
Omegatitis
Quote from: EMD on 29 July 2015, 22:35:14
Nope, same brakes  :y
Front brakes same even between 2.2 and 3.2  :y
Just vented rears on 2.6/3.2
EMD
I like the 3.0 engine  :) 3.2 would be thirsty around town .
Omegatitis
Quote from: EMD on 30 July 2015, 13:17:52
Can't see as they'd be a huge difference has you will be running the same 2.6 / 3.2 engine management as the 3.0 engine management and loom swap would be a backwards labour intensive move.
Higher compression on the 3.0 might shave a little off the fuel consumption. Then again, the ignition map on the 2.6 ECU might not suit it. DLK did the swap to good effect, though, if memory serves?
Quote from: Kevin Wood on 30 July 2015, 14:42:08
Aye, Daz kept the original Manual box and Diff (previous engine was a 2.6) so the car pulled rather well.
