Author Topic: Loom for blind  (Read 9451 times)
EMD
  • Noofhampton
    • 95t
Loom for blind
« on: 29 July 2015, 15:44:31 »
Can't find the loom for the rear blind . Ive put the blind in
but there Dont seem to be any cable to plug in  :-\
There's a connector in the boot that's not used but no wire off it ?
Do i have to buy the connector ?
Omegatitis
Re: Loom for blind
« Reply #1 on: 29 July 2015, 16:16:22 »
CDX might not have the loom fitted from the factory... especially a late one :-\
Be stuffed in the nearside parcel shelf cavity above the wheel arch if it's there... does it have the heated rear seat loom under the seat base? If yes the it will have the blind loom... if not, then it won't.
Be possible to acquire the looms for both and run them along the nearside sill and into the dash wiring at the two big plugs behind the front passenger kick panel. The wiring for both WILL be present in the dash
EMD
  • Noofhampton
    • 95t
Re: Loom for blind
« Reply #2 on: 29 July 2015, 16:53:39 »
Just had a look in the maintenance section and seen this quote ...
Whilst in the boot look in the far left hand corner, there will be a multiplugs connector, this is the power supply for the blind
I have the multiplug but nothing clipped into it from that leading up to the rear blind , no rear heated seats in mine . Ive asked s'fish who sent me the blind if he can look for the short loom otherwise ill be forced to power it up from a battery and leave the blind up  :y
No big deal as i leave the blinds up anyway but would be nice to have it all working .
Omegatitis
  • Online Online
Re: Loom for blind
« Reply #3 on: 29 July 2015, 17:44:44 »
Most on here seem to be of the opinion that  the rear blind is a pain in the arse.
Is it worth the aggro, Mr Emd?
EMD
  • Noofhampton
    • 95t
Re: Loom for blind
« Reply #4 on: 29 July 2015, 17:53:56 »
My patchwork quilt window tint wasnt a success  :-[
Omegatitis
Re: Loom for blind
« Reply #5 on: 29 July 2015, 17:58:01 »
CDX won't have heated rear seats... But the LOOM may be present... If it is, then the blind loom will be there somewhere...
Don't piss about with a short loom, obtain the whole blind loom, including the pins/sockets from tue plug in the passenger kick panel... Fit the pins/sockets in the correct pin location in this plug and simply plug the other end in... :y
If the blind was supplied without a plug then I would be looking for a refund :-X
EMD
  • Noofhampton
    • 95t
Re: Loom for blind
« Reply #6 on: 29 July 2015, 18:03:02 »
He's just scrapped the car today  :'(
Omegatitis
EMD
  • Noofhampton
    • 95t
Re: Loom for blind
« Reply #7 on: 29 July 2015, 18:11:56 »
Not sure what you mean , the multi plug is already there nearside on the car . Im missing the cable from the blind to the said multi connector so the loom is already there . Just need that short piece from blind to connector  :y
Omegatitis
Re: Loom for blind
« Reply #8 on: 29 July 2015, 18:41:45 »
Not including the loom from the blind to the car is just cu... ducks arseholes springs to mind :-X
    • 530D M Sport, 330i Coupe
Re: Loom for blind
« Reply #9 on: 29 July 2015, 19:00:53 »
I don't understand how you can't supply the loom and plug with the blind, you'd surely have to cut it to achieve that?
Re: Loom for blind
« Reply #10 on: 29 July 2015, 19:28:53 »
Indeed, hence my observations :-\
Unlews you only paid a tenner delivered, get a refund.
« Last Edit: 29 July 2015, 19:30:34 by Harris K Telemacher »
EMD
  • Noofhampton
    • 95t
Re: Loom for blind
« Reply #11 on: 29 July 2015, 20:20:27 »
Blind is a multi plug , just unclips . I presume he just uncliped the blind from the motor under the parcel shelf but its the wire from the motor to the cars loom that i need . if i cant get it ill just power the blind up and leave it up .
I could run wire from the motor to the multi plug or probably get another multi plug and wire it in that way ..
« Last Edit: 29 July 2015, 20:24:09 by EMD »
Omegatitis
Re: Loom for blind
« Reply #12 on: 29 July 2015, 20:52:23 »
Caveat emptor.
Get your money back and use it to acquire the correct loom/switch both of which should have been included ::)
Re: Loom for blind
« Reply #13 on: 29 July 2015, 21:18:26 »
I've never yet seen one sold without that lead attached, certainly the three I've bought have been complete. Oh well.
Re: Loom for blind
« Reply #14 on: 30 July 2015, 12:25:15 »
Worth going to a professional? Do you still have enough tint to supply to a company?
