Corsa replacement key complete
Started by powerslinky, 03 August 2015, 12:39:28
powerslinky
Hi all
            can someone point me towards the right item/s I need to make up a complete new key for SWMBO's '03 corsa.
Thinking e bay here but not really sure what I need or wether they are available from there.
We have one key , but it will not operate the locking remotely. Locking all works with key in the door , but not from the fob.
Replaced battery & tried to do a re-set with ignition on & pressing the fob , but nothing. Presume fob is fubared.
Fob is a hard plastic 2 button siemans type
Vx stealer wants £160 + vat for a replacement key  :o :o :o :o :o    Bit steep when I only paid £195 for the car ::) ::)
So can I get what is needed from e bay & then get it programmed by someone with a Tech2  or am I going about this all wrong ?
Any help greatly appriciated   :y :y
powerslinky
No response on this as yet so  . . . is there another way to get a complete new key for this 03 corsa apart from going to the stealer at a cost of £160 + vat ?  :'( :'(
btc
Don't some of the timsons (I think it's called ) cut and program key's instore while you wait
btc
Usual fault with them is that the switches fail, not to hard to replace so worth checking first.
Either that or its worth sourcing a new remote from Vx and getting it programmed to the vehicle using tech 2 (check you have the car pass!)
YZ250
Quote from: Essex Big Al on 04 August 2015, 06:51:08
Makes you wonder how the price is worked out.  :-\
My son-in-law broke the key in his ignition barrel a few weeks back and the barrel pin had snapped and jammed the ignition switch assembly, preventing removal of the plastic switch bit. I had to force it off and the tabs broke, but the car was still useable with a screwdriver in the switch slot as the steering lock was stuck in the off position.
My point being, he's just had a new ignition barrel fitted, a new key (for the door locks and coded to the car obviously) and a new switch for the barrel connection. All fitted at a Vauxhall Dealership for £120 all in.  :-\
Car in question is a 52 plate Corsa.
powerslinky
Quote from: YZ250 on 04 August 2015, 13:13:07
>:( >:( >:( >:(VX Stealers make my blood boil . . .  I was expecting to pay up to £100  but £160 + vat is cobblers surely.
The thing is we need 2 keys as we often use each others cars ( corsa is a lot cheaper on fuel than my 2  3.2's  ;) ;) )
If & when  I can get a second one made, I can then  see about getting the original repaired :y
powerslinky
Quote from: btc on 04 August 2015, 08:58:24
Found this
http://www.timpson.co.uk/services/62/key-cutting
Thanks for that , working right near the tesco store with Timsons in it tomorrow :y :y :y  nice one
btc
Brother in law used them a while back said they were quite good and a good price
Webby the Bear
Al, join the corsa owners club. theres a guy on there who does repairs for about £20 a key
RIP Paul Lovejoy
powerslinky
Quote from: Webby the Bear on 04 August 2015, 20:04:17
Ok Webby thanks  . .  . another route to pursue  :y   but I do need a complete new key as well as eventually having the exsisting one sorted  :y
powerslinky
£130 at Timpsons  . . but have to go to Dartford  . . TWICE :o     once to read the car ECU/key & then return to have it programmed once they have orderd it in  :'( :'(
It's an option  . . but am looking at other ways to sort this  :-\ :-\ :-\
Do you have the car pass? If so I would have thought a Tech 2 session would sort the programming so all you would need are the parts and a cut blade :-\
Quote from: Essex Big Al on 06 August 2015, 06:41:43
Surely there's a proper automotive locksmith in Southend that can do all this while you wait? A look in the yellow pages should easily find one. The company I use isn't far from you, but being in Gillingham the two rivers in the way would make it impractical. I'd expect it to be cheaper than that, too.
