99% certain the white one will be scrapped imminently...
Started by 05omegav6, 05 August 2015, 17:57:53
What to remove from it?
List so far...
Diff
Gearbox and clutch gubbins
Radiator
Ecu/lock set
Door motors
Door cards
Poly bushes
Tailgate
Lights
Irmscher kit
Calipers
Cats
Headlight sensors
Self levelling gubbins
Anything else?
Webby the Bear
what engine is this taxi? sorry I mean mr telemacher   ::) ;)
RIP Paul Lovejoy
Rear adjusters
Rear Poly donuts
A/C Compressor
Plod Springs
zirk
ABS ECU
Wing Mirrors
Air Con Hedgehog
Climate Panel
Power Steering Pump
Front Screen if good
Front Grill
Wings
Headlight Switch
Rads
Plod Head Lining Roof Covers
Roof Rails
If no rails, then the 4 Plod plastic hole covers
MID, and Stalks, Cruise.
To name a few.
Oh, and maybe the rear ns quarter panel.  :-\ ;)
Quote from: zirk on 05 August 2015, 18:35:43
ABS ECU
Wing Mirrors
Air Con Hedgehog
Climate Panel
Power Steering Pump
Front Screen if good Still broken
Front Grill
Wings
Headlight Switch
Rads
Plod Head Lining Roof Covers Long since binned.
Roof Rails
To name a few.
Oh, and maybe the rear ns quarter panel.  :-\ ;) ::)
Is that a shopping list :D
Storage might be an issue, as is time :-\
Front struts are due replacing and the engine is using/losing oil at the rate of two litres every thousand miles.
zirk
Quote from: Harris K Telemacher on 05 August 2015, 18:57:49
ABS ECU
Wing Mirrors
Air Con Hedgehog
Climate Panel
Power Steering Pump
Front Grill
Wings
Headlight Switch
Rads
Roof Rails
To name a few.
You did ask  :)
Shopping list, your need to get past my Bank Manager first. :'(
Oil leak, Ive got plastic bowl and some gaffer tape you can buy of me, should sort the problem out for another 200k.  ;D
Webby the Bear
Quote from: Harris K Telemacher on 05 August 2015, 18:43:56
Quote from: Webby the Bear on 05 August 2015, 18:01:54
3.2...
As you have listed ''clutch gubbins'' I assume it's manual.
is any of the inlet manifold (sandwich plate, inlets/injector assembly) fitting a 3.0l?
I have a 3l block that im looking out for parts for....that's assuming you even want to sell your bits. from the car  ::) :)
RIP Paul Lovejoy
Varche
Quote from: Varche on 05 August 2015, 19:19:04
err why are you breaking it?
I need to have one car... And this one will end up doing donuts in a car park over my cold dead body :-X
The other one is bodily better, done lower mileage and has never been written off...
Varche
Quote from: Varche on 05 August 2015, 19:40:09
has it ever been to WIM?
White one? About four times... Last time would have been January 2014 iirc... Ball joints now have play and on mileage the front shocks are almost due... Getting a bit wallowy now.
I can't drive it indefinitely as an unliveried plod mobile, and to finish it would require time and money, plus the hassle of trying to sell a 270k thrice written off ex plod Taxi for anything like the price of an advert makes the whole exercise rather moot :-\
Varche
EMD
Quotethe engine is using/losing oil at the rate of two litres every thousand miles.
Why's that then  ???
Omegatitis
Webby the Bear
Quote from: EMD on 05 August 2015, 20:56:37
Why's that then  ???
I'd guess a leak, Steve  ;D
RIP Paul Lovejoy
