Author Topic: Rear Heated Seats - A Question.  (Read 3556 times)
AND181
  • Central Scotland
    • 2.5 V6 Omega Estate
« on: 07 August 2015, 21:11:08 »
Just looking to see if anyone can point us in the right direction with the rear heated seats. We've got them in and we have connections (already in the car) but what we're unsure of is the looms, is there a 'joiner' loom we're missing?
It seems the loos for the seats don't joint the main body loom and we think there's one that connects them both.
If there is, any idea where we can source one?
Thanks
Re: Rear Heated Seats - A Question.
« Reply #1 on: 07 August 2015, 21:42:17 »
Body loom ends at a plug mounted in the rear seat crossmember beam... connecting loom contains two relays and plugs which connect to the tails from the seats. Switch wiring is present as part of the dash loom and are part of the rear cigarette lighter loom :y
Should be plug and play... :y
AND181
  • Central Scotland
« Reply #2 on: 07 August 2015, 22:04:14 »
So we have the switch wiring at the rear power sockets  :y
We also have the body loom at the rear seat cross member :y
The tails from the seats though don't appear to connect to the body loom, looks like we need some sort of connecting loom to go in between?  :-\
AND181
  • Central Scotland
« Reply #3 on: 07 August 2015, 22:05:19 »
Where can we get a hold of this connecting loom?
« Reply #4 on: 07 August 2015, 22:10:37 »
Pop a wanted ad in the test zone and ask a kindly admin to move it :y
Worth giving Steve at Omega Spare Parts a call too, as he might be able to help ;)
AND181
  • Central Scotland
« Reply #5 on: 07 August 2015, 22:13:53 »
Sweet, I'll do that now. Is it just a rear heated seats connection loom I'm asking for? Didn't know if there was a proper part name I should be asking for.
« Reply #6 on: 07 August 2015, 22:17:57 »
Sweet, I'll do that now. Is it just a rear heated seats relay loom I'm asking for? Didn't know if there was a proper part name I should be asking for.
Fixed, but yes :y
AND181
  • Central Scotland
« Reply #7 on: 07 August 2015, 22:26:04 »
Thanks you :y
« Reply #8 on: 07 August 2015, 22:34:24 »
Have a look in the maintenance section as there should be a guide... will make it perfectly clear :y
