Plumbing question
Started by TheBoy, 09 August 2015, 14:08:14
With the new washing machine being (presumably) cold fill only, is there a cap I can put over the hot tap/valve where the old hot hose would have gone to prevent diasaster if the valve/tap gets knocked or leaks?
I think its the standard 3/4" fitting...
Steve B
Can you not just remove the red plastic Lever Thingy  :-\
Quote from: BIGtime on 09 August 2015, 14:10:23
Yeah, but still wanted to seal it, as those valves are generally shite IME
Remove the tap & screw a plug in instead
this type of thing
Is there the opposite to that Andy B - ie one I can screw on the tap?
Quote from: TheBoy on 09 August 2015, 14:23:07
Ah! I'm with you now!
A quick Google .... and it seems you can. I've never seen one though  :-\
I'm never going to beat RobG am I .............  ::) ;D
Quote from: Andy B on 09 August 2015, 14:32:37
Screwfix 99p
Thanks Andy B and RobG, excellent, cheers :y
Even better RobG, I'll pop over to shitfix this afternoon :y
powerslinky
Advisable to fit a rubber washer inside the cap as well  Jamie   ;)
deviator
If you have the tools lying around, it might be easier and cheaper to fit a solder/push fit cap and a compression joint to the pipe. Depending on the exit angle, you may need to turn the outlet tap so the cap doesn't obstruct.
I've seen plastic caps for washing machine valves around, with integral washers.
Quote from: Essex Big Al on 09 August 2015, 20:06:55
Yup, it came with one :y
