One for Webby the Bear - Weber Carburetors
Started by Rods2, 10 August 2015, 19:26:47
Rods2
Webby the Bear
pretty cool stuff rods  :y
only got my bear paws on one carb before though  :-[
RIP Paul Lovejoy
YZ250
I broke away from the norm by fitting a Weber carburettor to both my Mini Cooper S and my 1275GT back in the day. Weber did a Torquemaster inlet manifold conversion that allowed you to bolt the carb on and still allow the LCB exhaust manifold to fit.  :y
A bit of a tweak by Oselli and away we went.  :y
Ah, those were the days.  :)
Quote from: YZ250 on 10 August 2015, 19:53:05
Yep tried a 45 DCOE on my 1293 Cooper S racer, then twin 40 DCOEs, best results 4x Amal carbs.
Also had  3 x Weber 40 DCNFs on my '72 Ferrari Dino 246 GT - bugger to balance
zirk
#4
Had a set of twin 40DCOE's on my Escort 1650cc.
1500cc PreCross Flow block (Ford, Lotus), 1600 crank, 1300 con rods, over bored PowerMax Pistons, Double Spring Stage 2 Gas flowed head, Blue Printed and Balanced, 421 Janspeed exhaust, RS Mexico bell housing with a Corsair 2000E 4 rail gearbox. Shortened prop and a Capri 3.1 Diff. Shit those were the days, not much on the road that could touch it, including Bikes.
Funnily enough just found a brand new boxed 28/36 Webber twin choke in the shed, anyone remember those,
Keith ABS
   My 3.0 S 1981 Senator had been converted to a Weber carb from the problematic GM item when I bought it. Apparently it won't be as quick as the origional as that was a four barrel item but it was reliable and achieved 30 mpg
Keith b
