rear bumper fixings
Started by pauls, 13 August 2015, 13:09:33
pauls
I am going to replace my rear bumper and I need to replace/fix the top fixing screw. Its the one that holds the top screw of the bumper around the wheel arch. Any ideas please as the clip and the screw came away from the car. Can I use a difference sort or do i need to perhaps try and fibreglass the area.
On the estate the clip to which the screw screws is on a bracket which locates tye top edge of the bumper on the rear quarter.... Expect saloon to be similar :-\
pauls
Its not on a bracket it looks like on of those flat metal clips that you push over the plastic and the screw tightens on the metal threaded clip. Trouble is when I took the bumper off the whole thing including the plastic from the car all came away together. Was trying to get a idea of how to fix it.
Quote from: pauls on 13 August 2015, 15:42:33
Not sure there's enough there to fix :-\ the plastic on the car IS the bracket... cannot remember if it's riveted or bolted on though :-\
Steve B
It screws into one of these Things, And the plastic is clamped between this fixing. (its your plastic thats bust i take it)
Quote from: BIGtime on 13 August 2015, 16:17:47
These things are called spire clips if you need to buy any. They're readily available.
Steve B
Think the issue Nick is there is nothing left to fix it to.  :-\
LC0112G
The end of the plastic locating rail is usually broken off by the time you've got the bumper off. The bumper screw rusts solid to the spring clamp, and then when you attempt to undo it, it breaks the end of the plastic locating rail off, leaving you with nothing to fix it back onto.
I had to search 4 cars in a scrapyard before I found an unbroken one when repairing my car.  New parts from Vx are ...
PFL Saloon RHS - 90458214
PFL Saloon LHS - 90458213
PFL Estate RHS - 90458933
PFL Estate LHS - 90458932
FL Saloon RHS - 9173412
FL Saloon LHS - 9173411
FL Estate RHS - 9147501
FL Estate LHS - 9147500
pauls
Thanks guys off to vauxhall in the morning :y
Fingers crossed then :y unbroken used ones are rarer than gold plated rocking horse poo with platinum highlights ::)
Lagondanet
Quote from: Harris K Telemacher on 13 August 2015, 20:47:21
Having had you replace my 2 bumpers I agree.  :y
Steve B
When i changed rear bumper i was aware about these before i started... N/S went ok but O/S was duff so i chopped bumper in that area then delt with it that way.Avoiding damage..But Bumper coming off is Scrap  :y
pauls
Just back from vauxhall ordered 1for each side. :y
