Author Topic: Brakes not sharp on initial application, improving with use. Pads?  (Read 2462 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Daughter Catherine has brought home her 2.6 manual saloon complaining of poor brakes in emergency stops. I have just given it a test drive. Brakes pull straight, no twitching, but poor on first emergency application from 30mph, improving on subsequent applications. Any suggestions?
davieboy0312
  • wishaw
    • 3l V6 saloon
Air in the system?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Crap pads.
Bleed system, fit new gm tc pads  :y
Hoof'land storeman.
  • Online Online
Crap pads.
Jeez! biggriff has gone all religious on us, advising peeps to fit genuine parts!!  :o  :P  ;D
Wot e said tho Terry!  :y
Some pads do need a hint of heat in them (TC included). Some need a lot of heat (eg, EBC, esp yellow and red). Some need no heat (such as OE)
hoody
  • Scotland
Worn wheel bearing can cause these symptoms too.
biggriffin
Crap pads.
Ive filling in for the middle earth one,while he's away, looking for the special.  ;D.
Hoof'land storeman.
terry paget
    • 3 Astras 2 Vectra
Thanks to all for advice. This morning I bled the brakes and fitted new GM TC front pads. After a 6 mile bedding in run I took my daughter out for a demonstration run and she declared the brakes 'now excellent'. Job done.
I thought they were OK before, but at least she is happy now.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
tidla
  • solihull
If the bearing has play in it then the disc can "widen" out the pads which on brake application need to travel a bit further.
Shackeng
  • Ramsbury
Re: Brakes not sharp on initial application, improving with use. Pads?
« Reply #10 on: 16 August 2015, 22:25:52 »
Hmmm, had a bearing going for some time and had no effect on braking, I suspect it would need considerable wear for this to occur. :y
