Need advice - Kitty is sick
Started by Gaffers, 16 August 2015, 18:47:34
Like Kevin Wood, I was thinking along the lines of over fuelling at idle. As soon as dumped in D, the fuelling is better.
Quote from: TheBoy on 17 August 2015, 18:48:20
Why the fast idle though :-\
If it can see its overly rich at idle, it may try to let some air in...
Gaffers
Quote from: Andy H on 17 August 2015, 18:17:51
Quote from: Monsieur Guffer on 16 August 2015, 20:09:20
Quote from: Andy H on 16 August 2015, 20:03:21
Quote from: Monsieur Guffer on 16 August 2015, 18:47:34
Spent some time today diagnosing the misfire on kitty (XJR6 X300'97 - last of the real jag straight 6's) and amittedly the lack of spare time means that it has been a while since I last looked at it.  Because of this i started from scratch with the diagnostics.
In Park - misfire is present through out the rev range and the engine is lumpy on idle despite high revs
In Drive - misfire is all but gone, revs drop to normal
Regardless of gear the engine responds perfectly to the accelerator, can take a while to come back down.
At idle:
Pulling plug leads one by one I saw that cyl 2 was the one misfiring.
swapped dis pack with anoth cylinder = no change
swapped plugs = no change
removed ECU and traced wiring back = no wiring issue
removed MAF plug = no change in revs
The last work done was changing the ICV Stepper motor but I havet driven her since.
So, my thoughts are now either air leak, faulty MAF or Ineed new injectors  :(
Those two symptoms shout air leak but I don't understand why the ECU doesn't control the idle speed correctly (unless it is a very big air leak)
Where does the brake servo vac pipe connect to the inlet manifold? is it straight into cylinder 2?
Is this a car that has worked for you in the past or is there a chance that a bodger has had a go at it before you?
Me too but i cannot find it.
i doubt it. To replace the ICV SM you have to take off the entire intake/iintercooler/tthrottle body.
I guess its my fault and i need to redo it :-[
I think I am missing something here  :-\ was it OK before you took it apart?
nope the icvsm needed replacing
Gaffers
Quote from: TheBoy on 17 August 2015, 19:03:43
Would fit with the symptoms. when cold the idle is normal speed just lumpy as f..... then after a minute or so the idle speed goes up to about 2k rpm without me touching anything.
Right next weekend its injectors off :y
