Need advice - Kitty is sick
Started by Gaffers, 16 August 2015, 18:47:34
Gaffers
Spent some time today diagnosing the misfire on kitty (XJR6 X300'97 - last of the real jag straight 6's) and amittedly the lack of spare time means that it has been a while since I last looked at it.  Because of this i started from scratch with the diagnostics.
In Park - misfire is present through out the rev range and the engine is lumpy on idle despite high revs
In Drive - misfire is all but gone, revs drop to normal
Regardless of gear the engine responds perfectly to the accelerator, can take a while to come back down.
At idle:
Pulling plug leads one by one I saw that cyl 2 was the one misfiring.
swapped dis pack with anoth cylinder = no change
swapped plugs = no change
removed ECU and traced wiring back = no wiring issue
removed MAF plug = no change in revs
The last work done was changing the ICV Stepper motor but I havet driven her since.
So, my thoughts are now either air leak, faulty MAF or Ineed new injectors  :(
T.m.f
Could try swapping injectors around 1st and see if it still miss fires on no2 cylinder
1996 300tdi manual discovery,the weekend mud toy and tin tent tower
The devil child ,aka mk2 2006 1.6 tdci focus
yeah I'd go with that plan. How did the plug look on that cylinder, any tell tales?
Gaffers
Quote from: aaronjb on 16 August 2015, 19:09:03
Sooty except for the end of the tip and the centre
Quote from: Monsieur Guffer on 16 August 2015, 18:47:34
At idle:
Those two symptoms shout air leak but I don't understand why the ECU doesn't control the idle speed correctly (unless it is a very big air leak)
Where does the brake servo vac pipe connect to the inlet manifold? is it straight into cylinder 2?
Is this a car that has worked for you in the past or is there a chance that a bodger has had a go at it before you?
Gaffers
Quote from: tunnie on 16 August 2015, 19:36:33
Does the cat run on gas?
No i need to get her running well on petrol first :y
Gaffers
Quote from: Andy H on 16 August 2015, 20:03:21
At idle:
Me too but i cannot find it.
i doubt it. To replace the ICV SM you have to take off the entire intake/iintercooler/tthrottle body.
I guess its my fault and i need to redo it :-[
Sounds to me like it's only when very lightly loaded, so when injector duration is at a minimum. Might be a lazy injector that isn't opening under such conditions, or is dribbling away all the time, meaning the mixture in that cylinder is too rich. Once the duration is up and the engine is under load, the dribble becomes insignificant.
Worth checking the compressions just in case something else is up, but also try swapping the injector to another pot. :y
Just to add, you can send injectors away to have them cleaned, refurbed and tested.
I've used this place before with good results: http://www.injectorcleaning.co.uk/post.htm
A lot cheaper than a new set and they normally come back in perfect nick.
I was thinking the same Kevin and another vote here for www.injectorcleaning.co.uk, good service and the turnaround was only a few days from posting off to getting back.
Gaffers
Sound advice, and easier to do than stripping everything down again (you think that Omega inlets are fiddly?)
Injectors easy to remove, are they?
henryd
Surely a compression test is first point of call  ???
other rides
tidla
Quote from: henryd on 17 August 2015, 11:32:46
I was thinking the same thing. Then some mentioned LPG and i ran away.
Quote from: Monsieur Guffer on 16 August 2015, 20:09:20
At idle:
I think I am missing something here  :-\ was it OK before you took it apart?
