Author Topic: 3.0 downpipes on 3.2  (Read 2211 times)
C20det
  • Belfast
    • 02 3.2 v6 Special
« on: 17 August 2015, 19:20:13 »
If I replace my 3.2 downpipes with 3.0 ones to do away with the pre cats & weld in some new bosses for the lambda sensors would this cause any problems? I.e any more eml come on or fail MOT?
Cheers
C20det
  • Belfast
    • 02 3.2 v6 Special
Re: 3.0 downpipes on 3.2
« Reply #1 on: 17 August 2015, 19:21:37 »
Would it be okay to use my 3.2 main cats with the 3.0 pipes or would need to get the 3.0 cats too
« Reply #2 on: 17 August 2015, 19:23:13 »
Better off moving pre-cat sensors to post cat, will solve the problem.  :y
    • 530D M Sport, 330i Coupe
« Reply #3 on: 17 August 2015, 19:39:50 »
Cheers
Yep 3.0 Cats will work fine as you describe, you will need to grind the ends off slightly though.
« Reply #4 on: 17 August 2015, 19:56:34 »
The downpipes and the cats are the same section/part.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #5 on: 17 August 2015, 20:03:20 »
Got 3.0L downpipes on my 3.2 no problems for mot., :y,
Bought the bosses  of ebay, welded in, grinded the shoulder down,new gaskets and splodges of exhaust gasket paste.
That's a quick summary. There is a more accurate how to. :)
Hoof'land storeman.
C20det
  • Belfast
    • 02 3.2 v6 Special
« Reply #6 on: 18 August 2015, 22:12:42 »
I have tried the pre cat sensors moved to post cat but still getting 02 sensor heater circuit open/malfunction problems  :(
Just found the how to guide on doing this  :y very helpful
Thanks for the replys people much appreciated
Page created in 0.008 seconds with 16 queries.
