XSARA PICASSO SX 16V
Started by EMD, 20 August 2015, 08:22:51
EMD
Anything that i should be looking out for on this mummy bus ? Its a 1.7 petrol , looking for a cheap runabout with room and spotted one that looks in decent nick but know nothing about these cars  :-\
Omegatitis
Being French there are obviously no reliability issues to concern yourself with. ::) ::) :)
Bit dull though. :-\
Actually a 1.8... check for accident damage as they are very lightly built... one reason why they're so frugal.
Trim is, well, French. Not a bad family hack, but a Zafira is more versatile and an Omega estate more accommodating, both for the same money  ;)
henryd
As already said very dull to drive but I look after loads of them and they don't seem to fare too bad for reliability(better than renault of same era)
other rides
EMD
Would make a cheap workhorse . Don't like French stuff
but if its cheap enough  :) Do all seats fold flat .
Omegatitis
I think that's what the father-in-law has.  Not the nicest of vehicles to be a passenger in ..... fortunately I've only been in it  a few times. His is the auto (automated manual) and the gear change is bloody horrible (as the interweb will agree)
Aren't the xsara's the ones with the complicated suspension setup?
Quote from: EMD on 20 August 2015, 11:02:14
The name Mr 99p is very appropriate. ;)
Quote from: STEMO on 20 August 2015, 12:01:02
No that's the 1955 DS. ::) ::) :)
henryd
Quote from: Andy B on 20 August 2015, 11:15:48
Thats the newer one and yes that bloody gearbox is awful :-X
other rides
henryd
No,pretty normal in that respect :y
other rides
Jusme
Lifted from PARKERS..
Would you buy this car again and why?
no,this car was a big mistake it is a total piece of junk every bit of trim rattles or creaks.
What's it like to drive?
roll's round corners,some really bad blind spots,more rattles and creaks than any car has a right to have
Have you had any problems with the car?
brake lights stopped working,uses a lot of oil,rough as old boots on cold/wet days when first started
I wouldn't buy another Citroen. I don't find the car fun to drive but she is practical so we will be keeping her for a couple of years while we save for something better.
Driven better. She is quite sluggish and has a habit of stalling if you don't keep fairly high revs, especially in reverse. Seems to use a lot of petrol for the size of engine but hoping that will even out now the pipe has been fixed. If you want something fast then believe me this is not for you. 0-60 in 20 minutes, lol.
We kept getting a petrol smell from the car but no-one could find any leaks. It was getting so strong the car was becoming undrivable. However, after a smoke test the problem was found in a pipe coming from the fuel tank that was hidden away in the bodywork (it looked melted?) so fingers crossed that has solved the problem.
Only if I found one really really cheap!
OK - its not really a drivers car but it does most things reasonably well.
Various recalls early on but after a few hassles with the digital dash it settled down fairly well.
Under-steer is when the front of the car hits the wall, and over-steer is when the rear of the car hits the wall.
Power is how fast you hit the wall and torque is how much of the wall you take with you.
That'll be the Sh1troen XM  :y
EMD
It'll be fine for tip runs and ladder runs  ;D If it gets dented
it Will be left dented  :D Now where did i put that 99p  ::)
Omegatitis
Watch out for melting fuse boxes! ::)
The French really should have stuck to Magnetos, starting handles and acetylene headlamps. ;D
