Any good???
Started by Jusme, 20 August 2015, 16:32:30
Jusme
Under-steer is when the front of the car hits the wall, and over-steer is when the rear of the car hits the wall.
Power is how fast you hit the wall and torque is how much of the wall you take with you.
T.m.f
It really depends what your going to be using it for  :y
1996 300tdi manual discovery,the weekend mud toy and tin tent tower
The devil child ,aka mk2 2006 1.6 tdci focus
Jusme
pretty much for what it lists, few electrical gadgets, and keeping battery topped up..
Quote from: Jusme on 20 August 2015, 16:32:30
Is it a worthwhile buy??  https://www.machinemart.co.uk/shop/product/details/clarke-1kw-inverter-generator-ig1000/brand/x-5-star-products
Thanks, that reminds me, I need to call MM - I sent my IG1000 off over 2 months ago to see if they can fix it (its never worked reliably), and not heard a Dickie bird since.
When it did run (which was never for more than 15 mins before failing), it did what it claimed. I'm dubious of the noise claims, as its quite noisy in use, even in eco mode.
The spark plugs are nigh on impossible to buy locally from garden centres, car outlets (likes of ecp, gsf, motorserv etc) or bike outlets.  MM do however sell the plugs.
Would I recommend it? Probably not.  I'm also dubious of the power claims, as a twin 400W heater, turned on one bar at a time, would stall mine every time.
Jusme
Thanks for that Jamie....  :y
Looks like a chonda to me (Chinese Honda look-alike).
I think I'd rather go for a 2nd hand Honda for that money. Even the pre-inverter EX series Honda generators are great. Quiet, frugal and honest about their output. You can often pick them up cheap with simple faults and fix them. The contest group I belong to run an EX800 for 24 hour radio contests regularly and it doesn't miss a beat. For larger setups we hire a 40kVA trailer generator, which also doesn't miss a beat. ;D
Quote from: Kevin Wood on 20 August 2015, 23:22:38
Like most Clarke/Sealey stuff, its Chinese sourced tat, rebadged and price bumped.
