what brand pads;
Started by jimjimanta, 22 August 2015, 15:11:33
jimjimanta
I had befriended a very cheap pads in the car. 30 euro back and forth ....
The problem is that the brakes excessively whistled, and we will change it.
You what my brand SUGGEST;
basics they will not make noise.
Brake squeal can be eliminated by using coppaslip on the rear of the pad.  Genuine GM pads also do not squeal usually, but cost a lot
jimjimanta
#2
what is coppaslip ??? and what i do ?
jimjimanta
Quote from: jimjimanta on 22 August 2015, 15:25:09
http://www.molyslip.co.uk/copaslip.php
I'm sure you'll be able to get it nearer to home. Other similar compounds available, but Molyslip is far superior to all of them.
Smear it on the back of the pad to reduce squeal.
Quote from: jimjimanta on 22 August 2015, 17:18:44
from this product : http://www.onparts.gr/opel-omega-b-estate-21_--22_--23_-2-0-16v-136hp-136hp/antallaktika/antallaktika-service/takakia-empros
my car with lucas system .
what you recommend;
Opel own pads (not Opel aftermarket) are the only ones that definitely will not squeal.
Out of those ones you've linked to, Pagid (preferred) or Jurid
jimjimanta
pagid is very expensive . with 70 eyros , buying opel pads ... is better than the Opel;
for ate , what is your opinion;
please suggest some brands that you consider good. always in comparison with the authentic Opel.
what is the brands , in the original pads opel ?
The manufacturer of the Opel pad do make aftermarket pads, but THEY ARE NOT THE SAME PAD!
As said, which ever caliper is fitted (ATE on early 2.0l, Lucas on all others), I'd recommend Opel/Vauxhall OE, esp if you want to get rid of squeal. Other good options are Pagid and Jurid.  I don't believe the "tradeclub" pad set is available outside the UK, and certainly not a tradeclub prices :(
Anything else is usually poor in my experience, and I've tried a fair few.
jimjimanta
thanks for the informations .
Purchase Today the kopaslip.
how to apply it;
I'll put the finger in pads;
Does anyone Installation Guide;
