anyone run extra gauges oil pressure,,boost
Started by jamiew, 24 August 2015, 18:26:25
jamiew
As title guys Gonna fit a oil pressure temp and boost gauge anyone got any pics of where they have them fitted thanks  :y
Gaffers
jamiew
Abs ain't disconnected it's been removed completely when I fitted my monaro brakes asking for help not smart comments  ;)
I guess location of extra gauges all depends on car being facelift or pre-facelift, that said, if you look in the 'chav me clit' section of Hellfrauds I'm sure i've seen the instrument pods that mount on the A pillar.
If it were a left hooker, I would have suggested dumping the MID and fitting a cluster from the Catera as they have both... but guess it's a UK car... could modify the centre vents into a pod ;)
Quote from: jamiew on 24 August 2015, 19:10:12
Was answering MGs question... but as the ABS ecu is what drives the speedo, that's another puzzle solved :y
Gaffers
ergo, disconnected. ..surely?
You'll find that people here are generally quite smart*.  So if you want less intelligent replies ::) ;D
*With the exception of that Mr DTM fella, he's not smart....oh nooooo, not all  ::)
jamiew
Yeah it's a facelift model want something oe looking as possible don't want gauges on pillars etc in the vent could be an option though
Centre air vents, as you say, are probably your best and only option. You could remove the ashtray but it's not that deep so might struggle to fit gauges and is far too low to be any use unless you are the height of a Meerkat!
Gaffers
Quote from: jamiew on 24 August 2015, 19:20:59
The problem will be finding moulds to fit the vents, would have to be custom made i guess.  Plus you'll lose the effect of the vents.  Might be easier to fit on top of the dash but then it might encroach on line of sight and become n mot issue.
Arguably the centre vents are redundant... besides, as dash trim goes, it's a doddle to remove and therefore lends itself to experimenting with... helps with routing the wiring too ;)
jamiew
Don't like them on dash etc but want to keep an eye on oil temp and pressure when running near 500bhp :o
Gaffers
i am guessing you must have updated all the running gear too.  Not sure the OE could handle that many ponies :-\
Gaffers
wasnt there a german project along similar lines and he had an issue with the diff overheating?
