Not a bad effort
Started by EMD, 25 August 2015, 15:01:14
EMD
This is my first attempt at making something with the arc welder , ok the welds are not great yet but im getting the hang of it  :) Need some wheels for this welding trolley , ill add a top tray and a hook for the handle and wires  :y Just making use of the off cuts i have so its all made from short pieces .
Omegatitis
EMD
Quote from: Doctor Opti on 25 August 2015, 15:45:52
Looks good to me. :y
Thanks mr opti  :) I was quite amazed at how it turned out . One thing im not sure about is how far down to let the rod burn to  :-\ Being an old skinflint i try and get as much out of an arc rod as possible  ;D , but the nearer the end it starts playing up and sticking . Its quite satisfying building steel things  :)
Omegatitis
It looks straight and true. :y :y
Quote from: Doctor Opti on 25 August 2015, 18:52:25
He could construct the metal frame for your new orangery  :)
BazaJT
Looks good to me,and is certainly a damn sight better than I could probably manage :y
Quote from: STEMO on 25 August 2015, 18:54:32
Luckily for me I have the skin of a Rhino. :P :P :P
EMD
Quote from: BazaJT on 25 August 2015, 19:57:57
Well i thought i would give it a go . Ive learnt to check that my apron is covering my legs properly after getting a few bobbles of weld splatter burn through my jeans  :o
Omegatitis
Well done  :y
Looks really good, love to be able to weld  :)
Quote from: EMD on 25 August 2015, 22:23:14
Wait until you're lying under a car welding  ::)
Top tip... Don't wear a fleece  ::) Or a watch :o
EMD
Quote from: Lazydocker on 25 August 2015, 22:47:26
I now understand why people wear a baseball cap on backwards  ::) I burnt my hair while welding the last few bits  :( Need a baseball cap now but not wearing it at jaunty angle while driving the car  ::)
Guess im lucky i have some hair to burn  :P
Omegatitis
the alarming man
they do say an inch of weld should be able withstand a ton....not sure if that is true
EMD
The finished product  :)
Omegatitis
Mr.OmegaMan
