About this Ford
Started by EMD, 01 September 2015, 18:06:44
EMD
Been looking for an estate and these Mondeo look cheap as chips but what about any pitfalls with the engine or wear and tare stuff  :-\
This is just an example of what car i mean but you can get them a lot cheaper :
Mondeo
Omegatitis
Whilst miles better than its predecessor, its unloved compared to the later ones, which are much better.
The 2.0TDCi is known for DMF failures and injector faults (which can lead to excessive engine wear, and even seizure).
EMD
Quote from: TheBoy on 01 September 2015, 18:40:32
Ill pass on that then  :( Going to get rid of the 2.5 manul first then look for mig estate .
Omegatitis
tidla
Petrol model yes, diesel, noo.
to add, turbo actuators,water pump/power steering separation, chain tensioner wear,aux belt pulley disintegration.
Did somebody mention dmf which clogs up the starter with fine dust..
Wouldn't touch one of those with yours... and that one screams ex taxi :-X
Quote from: tidla on 01 September 2015, 18:50:26
I would second all of that. Injectors, turbo or DMF are all four figure jobs, and are a case of when not if. They're the reason why a tidy looking TDCI Mondeo can be bought for £500. It's a pity, as a working one is a good car.
omegod
I recently broke one for decent money, timing chain had been set wrong and damaged the top end ! There's a very strong demand for injectors, dmf , high pressure fuel pump's and turbo's so take that as you will !
Varche
I hate to say it but for that sort of money it is almost "disposable car" territory.
i.e. buy it, run it till something serious goes wrong. Hopefully get a year or so out of it. Any longer is a bonus. Then break and/or scrap . Years motoring for £600? (about three weeks hire car)
Then buy another.
Yep I'm with Varche on that.  It's Bangernomics! :y
I bet on the Mondeo forum if someone says 'Hey these Vauxhall Omegas are cheap!' there will be pages of reasons not to buy one. eg. They all leak oil, they all leak water, weak suspension, chew tyres for a pastime etc etc  ;D
Quote from: Varche on 01 September 2015, 21:38:50
Then buy another.
But a £600 Mondeo is likely to already be exhibiting some or all of these symptoms. That's why it's £600! I saw one last week that he had owned for 10 days with a knackered startermotor. We bumpstarted it, and it had a nasty vibration through the clutch pedal - classic DMF symptoms which mean a new flywheel, clutch and starter.
Bangernomics requires a cheap car that will last for sometime without any money spent on it. A cheap TDCI Mondeo is far too much of a gamble to qualify. Buying one from the top end of the market doesn't reduce the risk by much either.
Quote from: Harris K Telemacher on 01 September 2015, 19:28:02
Speaking of which, I wonder if the new owner of a gleaming white Mercedes estate is aware of it's history?..... ::) ::) :)
Quote from: Doctor Opti on 02 September 2015, 11:39:28
;D
EMD
I have emailed someone about a pf 2.5 v6 Ghia estate  ::) :-X
Omegatitis
Quote from: Sir Tigger on 02 September 2015, 13:26:37
;D
I emailed the vendor this pic...
...Just to be clear ::)
If a car is a high miler, even though it's fairly young, what difference does it make if it's been used as a taxi? If the service history checks out ok and the upholstery isn't full of puke, then it's the same as any other car that's had a hard life. The price you pay should reflect this. I would be more put off by a well-used shin breaker.
