2.5td box into 3.0 litre omega
Started by sax-p, 03 September 2015, 15:12:18
sax-p
Question is will they bolt up? Ie starter.  Also what clutch and flywheel can I use?
Or will it be easier to get a manual box and setup out of a 3.0? Also would a 2.0 box and stuff fit?
Sorry for all the questions but want to try and start driffing on the cheap.
Thanks
Trev
Check out my 04 omega project ;)
The bell housing between V6 and TD is different, swap those over and all should be fine I would think.
biggriffin
#2
Round and round the mulberry bush, ;D
another perfectly good omega about to be wrecked, be wanting a lsd next :-\ brace yourself.
Glad mine went to a good home.
Hoof'land storeman.
Keith ABS
  One quick queiry here regards the LSD. Does anyone know if the Senny/Carlton LSD is the same as the Mig item?
Keith ABS
biggriffin
Quote from: Keith ABS on 03 September 2015, 19:05:28
Keith ABS
incoming keith
Hoof'land storeman.
sax-p
Quote from: biggriffin on 03 September 2015, 17:53:37
Car already has an lsd, I'm not wrecking it. Car is being scrapped due to rust.
sax-p
Quote from: tunnie on 03 September 2015, 15:59:41
Thanks, will try that out.
