Which diesel? Or Alternatives?
Started by deviator, 06 September 2015, 15:25:57
deviator
I am in the position that I may well need a diesel estate for work. Judder. I am hoping it will be as well as Omega, as my car is worth so little  ::) (Keeps the wife happy)
Here is the problem I have...
Limited budget, probably about 1k
I'm not a fan of French cars
I've done the VAG thing and found it expensive to repair, overly complicated and for some reason, older VAG cars seem to suffer with everything plastic/rubber giving up. Like insulation falling off wire in engine bay.
I doubt I could find a BMW I'd want to drive in that price range.
I'm not a fan of Ford and their chocolate bolts (I had a Mondeo, I put the socket set away and used the Irwin bolt removers - yes it was that bad)
I like Vauxhalls, but I find the current (in budget) range bland, heavy and awful visibility.
I know diesels can be a world of hurt because of DMF, injectors, swirl flaps, EGR, DPF & turbo. It will be a relatively short ownership car, once I am up and running, I'll be in a situation were I can afford to throw more money at it to try and improve reliability.
A Omega with LPG, is just about possible, I think. I get 27mpg out of my 2.6 manual estate, so another third (equivalent) improvement would just be a little below what the 40mpg-ish I am aiming for.
I am open to any whacky, fruity - even sensible options I've not considered.
Vectra B estate is about the only thing that springs to mind :-\
Thinking outside the box slightly... how about an Astra van?
Your issue is budget... lets say you find a nice Omega estate for £800... lpg would add another £8-900 to it...
That said Robsey has an lpg estate for sale :y
deviator
Harris thanks for the suggestions, I've spent most of the last 10 years in a GSI Vec B, I doubt I could go to diesel. It would be too much of a backwards step.
I've already ruled out a van as I will be staying in hotels and carrying tools. A van attracts too much of the wrong sort of attention. Whereas I can false floor an estate, raise the carpet up and it looks like another rep-mobile.
The budget does have some flexibility, if the fuel economy stacks up OK, I'd pay extra to be in a comfy place like an Omega and I wouldn't have the diesel issues either.
I noticed Robsey's estate for sale, but I'm not quite ready to buy and I suspect it'll be long gone in a few weeks when I need something.
Mercedes C or E Class.  :y   If you can find an un rotten one within budget that is.  :-\  ;D
brendan1983
Due to the number of miles I'm doing lately I've picked up a 2004 Nissan Almera 2.2Dci (136Bhp)
Obviously its nothing like an omega to drive, but it's got lots of torque - and I'm averaging 55-60mpg out of it. If you needed something bigger you can get the same engine in the Primera.
2003 CDX & Yamaha Thunderace
deviator
Good suggestions, for some reason I'd not considered Jap diesels, I don't know why.
Quote from: deviator on 07 September 2015, 17:36:57
Because they are generally behind the euro designs
Probably the Renault engines that Nissan do so love to use ::)
Quote from: TheBoy on 07 September 2015, 17:46:06
Behind in the respect that they don't spend half their life in the workshop?
It seems like one of TB & Al must be wrong ..
TB says they lag behind European designs.
Al says they use European engines and that's why they're not worth considering.
*scratches head*
:P :P :P
Have you looked at the Toyota avensis? Might be a bit pricey for you, but could be suitable.
henryd
Quote from: aaronjb on 07 September 2015, 19:26:55
*scratches head*
:P :P :P
2.2dci Almera motor is deffo Renault's
other rides
