Removing battery - LPG
Started by geoffr70, 07 September 2015, 13:28:46
geoffr70
Hi peeps, will changing batteries on my car affect the lpg system in any way? Thanks
TC and BnQ Trade holder.
geoffr70
If it off for a long period (read several days plus) you might loose the map, but highly unlikely :y
zirk
Quote from: Lazydocker on 07 September 2015, 18:24:48
Yep, I had a couple of LPG's that have been parked up (with Battery diss'd) and have lost the LPG Map.  ::)
Maybe that's down to the system?  :-\
I've parked mine up several times over the years with the battery disconnected, the longest about 10 months and every time it's worked as it should when reconnected and started up.  :y
I would think most LPG systems would store the map in Flash or EEPROM memory, so requiring no battery power to keep the contents. Other short term "learning" parameters might be in battery backed RAM, but I wouldn't have thought they would affect running badly after the first start up.
geoffr70
Thanks for everyone's replies. I changed the battery yesterday. Now the car is noticeably more sluggish on lpg and I can hear the lpg injectors now, whereas before I couldn't. It's fine on petrol. Will this get better after a few more miles?
The car in question is a 2000 Astra 1.6 8v. I don't know the make or kind of lpg system it has.
Thanks peeps!
