Wynns Super Charge
Started by Webby the Bear, 09 September 2015, 22:56:12
EMD
As henry said its knackered  :( Funny how most seem to suffer
on the drivers side bank  :(
Are the lifters expensive ?
Omegatitis
Quote from: EMD on 11 September 2015, 12:45:10
Best to source known good ones from breakers.
On a visit to MasterDTM, he kindly gave me a set. Some time ago now  :-[
Let it tap. As soon as you fix them something else will break.
So £6.25 each, delivered then :D
Quote from: Harris K Telemacher on 11 September 2015, 13:30:38
I think they're about £15 each if bought singly.  ;)
biggriffin
Many years ago, they were called viscosity treatments, (stp-wynns-redex) then they allowed the motorists to have synthetic oil, so you shouldn't need an oil tweetment,if you cange the oil regularly, it should stay within its viscosity spec.
mineral oils go out of spec, hence the need for improvers(tweetments)
Hoof'land storeman.
EMD
Super- charge , mr bear needs this  :)
Omegatitis
Webby the Bear
Quote from: Marks DTM Calib on 11 September 2015, 10:30:27
With the exception of lifter treatment, I would always advise using a good oil and absolutely nothing else. If the engine has issues then no magic potion is going to correct them
So, if one was to try aforementioned gloopy sh*t then it could free up a chunk of carbon and clog strainer?
RIP Paul Lovejoy
Steve B
#24
No very early ones are tad different, but I think all after 1997/8 ish are the same?
