Wynns Super Charge
Started by Webby the Bear, 09 September 2015, 22:56:12
Webby the Bear
Anyone ever tried this stuff? I put a tin of it in a car today at customer;s request (with an oil change) and got to say it was noticeably quieter immediately!
have seen more than one video where this stuff puts compression back up when one cylinder was off! don't know why but thought about trying it in the omega.
RIP Paul Lovejoy
henryd
Snake oil,the only one I've seen work is the lifter tonic and that's pretty good
other rides
Formulated to maintain oil pressure at high temperatures , improve performance and compression in worn engines , reduce oil consumption and exhaust smoke, quieten noisy engines, reduce friction and wear , prolong engine life and be safe with catalytic convertors and turbochargers.
If 2.2s oil consumption comtimues, might chuck a can in for a laugh. But so far, had little luck with Wynns products.  :-\
Webby the Bear
Fair enough boys. thing is I suppose these yutube vids can be rigged  however they want!
there'd be no harm in chucking some in to the omega, right?
RIP Paul Lovejoy
Halfrauds sell a tin for £7, think with trade card should be around a fiver.  :y
plym ian
Quote from: tunnie on 09 September 2015, 23:05:38
Im glad its not just me using shed load of oil in a 2.2
Quote from: Webby the Bear on 09 September 2015, 22:56:12
Hardly a test though......you put it in and changed the oil........the lowering of noise could be the additive (it wont be) or the fresh oil (most likely)
Quote from: plym ian on 10 September 2015, 07:24:03
It's been fine until about 181k - never used a drop. Now it needs a very small top up every 750 miles or so. I'm keeping an eye on it  :-\
Webby the Bear
Quote from: Marks DTM Calib on 10 September 2015, 08:14:43
Fair comment.
Is there any harm in trying it? i.e, stuff in, it dislodges a bit of carbon, oil strainer clogged....you know the rest..
RIP Paul Lovejoy
With the exception of lifter treatment, I would always advise using a good oil and absolutely nothing else. If the engine has issues then no magic potion is going to correct them
EMD
Quote from: Marks DTM Calib on 11 September 2015, 10:30:27
Ive used 3 bottles of that lifter treatment and 3 oil changes but still it wont get rid of the tap tap lifter noise from the drivers side  :(
Omegatitis
henryd
Quote from: EMD on 11 September 2015, 11:21:31
That'll means its fooked then :-\
other rides
I do wonder about GM's penny pinching in later years, my 3.2 has the same problem. Dead lifter, lifter treatment no good either  :(
EMD
Ive tried thrashing mine but it dont make any difference . Im saving to get it done at sereks over the winter , think that will be a totally rebuilt engine after that  ::)
Omegatitis
Quote from: EMD on 11 September 2015, 12:28:33
I did just once, get it to shut up when hot. I'd parked up, but was at engine idle for a while. Parked on a double yellow  :-X
I made a get away once I saw traffic warden coming, it was an annoying day, so from idle to red-line several times  ::)
Stopped again, silence.  :o Did hope I fixed it, but nope back again. Defo a busted lifter  :(
