Win 10 Problems
Started by Mr.OmegaMan, 11 September 2015, 17:37:51
Mr.OmegaMan
Well Win10 has finally broken my trusty Tosihiba lappy.....
The other night the Laptop just shut down out the blue by itself, Now i can't get it passed the black screen that follows the windows logo. There's no cursor, Nothing just a black screen.
I did manage to get to the to "Choose an Option" menu where the following options follow..
Continue - Exit and continue to Windows 10 (didn't work)
Troubleshoot - Reset your PC or see advanced options...
Turn off your PC - (doesn't do anything to help)
So here are the Troubleshoot options...
Reset this PC - Lets you chose to keep or remove your files, and then reinstalls Windows (didn't work got some kind of error)
Advanced options menu next...
System Restore - (doesn't work)
System imagine Recovery - (windows cannot find a system imagine on this computer)
Startup Repair - (doesn't work)
Command Prompt - does allow input put I'm not that advanced enough for that.
Go back to the previous build - it couldn't find anything so that's a bust also.
Startup settings - I do have acces to these.
Any ideas guys I'm lost at this point.  :-\
Unless you are IT savvy, I'd stay away from Win10 for now.
So, I'd suggest rebuild as its previous OS if you're not IT savvy
or
I'd suggest rebuilding as either previous OS or Win10 if you are.
Mr.OmegaMan
Quote from: TheBoy on 11 September 2015, 21:06:33
or
I wouldn't know how to rebuild it tbh... Normally something I'd take it to a shop for, But I'm trying to save what's on the HDD as I don't have a recent backup.
Just a thought...
If I removed the HDD and buy a docking station and connect it via USB to my old laptop shouldn't I be able to retrieve my pictures, videos, files etc?
Mr.OmegaMan
Mr Gav
It could be a graphics problem and not windows 10, I bought a new GPU which packed up after 4 hours, same symptoms, get the post screen then a black screen and nothing else, it may even be a drive issue if there have been some recent updates.
As for the docking station I`m not sure if it would work, I`ve used a old hard drive in a desktop and that worked so it should but couldn`t say for sure.
So you upgraded to Win10 and didn't take a backup :o.  From that, its clear you don't actually need anything that's stored on there ;)
Did you set up One Drive with the Win 10 upgrade (or if you had Win8.1 before)? If so, you may find some of your data on One Drive, depending where you stored your data.
But, yes, some kind of USB<>SATA adapter should allow you to see what is (left) on the disk
zirk
#6
A USB Drive adapter or empty 2.5 hard drive caddy will do, sometimes cheaper to buy a 2.5 USB external Sata Hard Drive in one, then with a couple of screws you got yourself a spare Hard Drive and an encloser at hand.
Depending how old your other Lappy is you may have to take Ownership of your Win10 Drive, but Win7 upwards should just see it.
Any Files you stored on the Win10 Drive will be in C:/User/blah,blah/Documents, Videos, Desktop etc.
If you Installed Win10 over an existing OS, your order / other files will be in C:/Windows.old, User/blah,blah.
You really should back up your HD before doing any Major mods or OS upgrades, personally I'm a great Disk Cloning fan (like for like on a spare Drive(s) rather than rely on Restore, Windows Image, Back Ups etc, might take longer to do, but a least that way if the worst does hit you, you've got another Hard Drive to get back on quickly and then a means to start researching or repairing your failed Drive.
Mr.OmegaMan
It's roughly 7 years old the spare/old laptop on Win Vista it is also a Toshiba, That docking station from Amazon should be here tomorrow i'll see how that goes before trying anything else.
I do have in the region of 70% backed up to a Samsung D3 2TB hard drive, It's just the more recent stuff that's not backed up... I'll admit it's my fault for not doing a backup more regularly and when I installed Win10 etc..
No idea about Google drive as anything cloud based isn't an option for me with BT broadband 2mbps download - 0.35mbps upload. Granted I could leave it over night to upload etc..
If the worst comes to the worst i'll just have to make a small sacrifice this time round and in the future backup each time I use the laptop or at least once a month.
Auto Addict
Quote from: Mr.OmegaMan on 12 September 2015, 15:38:47
Quite a number of older Toshiba Laptops do not support Win 10, check Toshiba web site for details.
I like red cars
Quote from: Auto Addict on 13 September 2015, 09:05:09
You gettin involved in technical stuff there, Barry?  ;D
Auto Addict
Quote from: STEMO on 13 September 2015, 11:50:49
You bet, still playing Captain Comic :y
I like red cars
Mr.OmegaMan
There's no win10 on that older laptop that's the spare I'm using while my other one that was originally on win7 when new and is roughly 3-4 years old that's the one that's playing up, The plan is to use the older Toshiba laptop on Vista with the docking station to try and retrieve data from the HDD on the one that's refusing to fire up.
Mr.OmegaMan
So far the HDD docking station is successfully transferring data to an external Samsung D3 2T hard drive via my old laptop.
There's some 200GB that needs to be transferred and the estimated is around 3 hours.
After this has completed i'll give Win10 one more chance with a fresh instal.
