A bit of homework, Project E
Started by Marks DTM Calib, 16 September 2015, 16:27:59
Quote from: TheBoy on 24 September 2015, 18:56:34
I thought you could do the sparks, but it needs to be tested and signed off by a qualified sparky?
Who presumably won't sign off shit unless they've paid some spotty yoof peanuts to do it done it themselves ::)
that's what I thought  :-\
Shackeng
Quote from: Marks DTM Calib on 24 September 2015, 08:17:28
Quote from: Shackeng on 23 September 2015, 19:45:27
Nice job Mark. When the steels are in, can you keep the ceiling line smooth coming out into the extension?
Yes we could however, we took the decison to have a vaulted ceiling due to the two large Velux windows that are going in  :y
:y :y :y
Quote from: Harris K Telemacher on 24 September 2015, 19:36:49
Fortunately I have a tame spark :y
Was the same when we fitted our log burner... Found one person who would sign it off... For £800 :o He  just told me to find someone else >:( In the end I just paid a different firm to fit it all as well as supply. Turned out for the better anyway as my grumpy neighbour complained about it ::)
Some further progress after a few hours of work yesterday. jack rafters cut and fitted in the gable end:
Does a vaulted ceiling increase cost? Couple of extensions on identical houses near here, have "normal" celings. Does I feel restrict light, and vaulted would be much better.
Probably very little in it (dependent on size  of roof and design), key thing with a vaulted ceiling is the insulation type used is more expensive than normal rock wool but, you don't need ceiling timbers.
We have two large Velux windows going in and a vaulted ceiling results in much more light coming in plus we have the vaulted section above the bi-folds which will be glass, again ensuring the existing rooms remain light.
Gaffers
For the extension I have in mind chez Guffer I was thinking of a Orangerie-like lantern but this is giving me ideas of areas to reduce cost :y
Quote from: Monsieur Guffer on 28 September 2015, 13:18:50
The design is very much focused on getting maximum light without compromising on the practical and energy efficient considerations  :y
Gaffers
Quote from: Marks DTM Calib on 28 September 2015, 14:42:38
I don't suppose you made any calculations on the energy efficiency with a lantern, per chance ::)
You know, plagerism is the highest form of flattery and all ;D
I have calcs for the U value which is about 20% better than the current regs require.
Add in the wet under floor heating and increased artificial lighting and its going to 'ok'
Gaffers
I will have to keep investigating.  Before I do anything I will have to move a communal sewer drain (5 in, 1 out) which will overly restrict what I can do if it remains where it is.
That alone is probably going to cost about £2k :'(
You folks are lucky, you can do a bulk of the work yourselves.
I'd be looking at £25k easy if I was to extend. Would need a company to do it for me. Already have one wall thanks to the garage. (brick only)
Extension would only be ~14ftx10ft
Someone had similar done in the street. Set him back £30k  :o :o
Gaffers
Tbh, I was going to project manage it for the most part and do the bits I was comfortable with.  All the key parts such as foundations, brickwork, roofing, etc I was going to get someone else to do.  I have a few mates in the construction business with contacts :y
redelitev6
 :y Nice work ! that aint going to fall down any time soon
