A bit of homework, Project E
Started by Marks DTM Calib, 16 September 2015, 16:27:59
Sorry.......must read and remember what I read...... :-[
Quote from: STEMO on 23 March 2016, 20:41:46
You did pressure test the underfloor heating before you did that.....didn't you?
To answer anyway, 4 bar air pressure and its still 4 bar as of last night  :y
henryd
Quote from: Marks DTM Calib on 24 March 2016, 11:38:14
It'll be a bugger if it drops now :-X ;)
other rides
Well it wont be the pipe if it does  :y
Damn sight better than my C/H system manages (mutter, mutter) ;D (starting to think it's leaking into the concrete floor .. joy!)
Anyway......UFH is still showing 4 bar.......  :y
Loads of progress and this despite a further trip to the wrong side of the planet on business!
Stud wall constructed to create the separate man cave and kitchen area, the kitchen half has been boarded and plastered plus the first fix plumbing added:
Once dried, the plaster had a coat of well watered down emulsion to help seal things and then last Friday, the kitchen arrived.
Queue a busy weekend of fitting units:
More units to fit yet and various bits of trim and finish to add (about 7-10 days worth in between going to work and other commitments) before they measure for the worktops (next Thursday, with fit the week after).
Viral_Jim
Looking good Mr Mark  :y
Are you DIY'ing everything? Very professional looking plaster and brick laying finish if so!  :)
Steve B
Thats looking good mark  :y  The end is in sight
Quote from: jimmy944 on 25 April 2016, 14:48:56
Plastering is an art, I built the stud and boarded it out but go some pros in to do the skim etc.
I did all brick work below DPC and got a couple of brickies in to throw the rest up (to save time!)
Everything else is my own work  :y
Viral_Jim
Quote from: Marks DTM Calib on 25 April 2016, 14:51:05
Impressive stuff!
SWMBO and I are about 3 months off completing our renovation ("back to brick" on our 3 storey victorian place), I took the same approach as you, I'll board out but not do the actual plastering. However I'll only do brick/block work if its being rendered or plasterboarded over - just not a skill I've ever acquired!
Quote from: jimmy944 on 25 April 2016, 14:56:22
Impressive stuff!
I don't mind brickwork, its all about corners and then the rest is easy, I am just not overly quick at it!
However, by doing the foundations it means its mega square and level which most brickies don't worry to much about.
First fit kitchen complete including the island and the various end panels.
Today they template for the worktops and the floor tiles arrive, in theory the kitchen should be all but done by the end of May
Quote from: Marks DTM Calib on 05 May 2016, 08:14:40
Today they template for the worktops and the floor tiles arrive, in theory the kitchen should be all but done by the end of March
Typo or deliberate? ??? ::)
raywilb
#149
Quote from: zirk on 16 September 2015, 16:32:22
Looking good there Mark, and looks like bloody hard work. :y
Take it you got planning permission.  ;) ;
probably didn't need it , just building regs . looks a nice tidy job . speaking as city & guilds brickie ( retired )
. :y :y
