Author Topic: MaxTrac Shocks - A Review  (Read 1758 times)
« on: 19 September 2015, 20:09:34 »
I did want Meyle shocks, but AGP said they would be at least 3 to 4 weeks. I was recommended MaxTrac, they are made to OEM spec and came in at under £50 the pair with an OOF discount.
A few pictures, note the fitting kit is almost identical to GM.
Front row is MaxTrac kit, back row is 1 month old GM fitting kit.
They replaced knackered GM's so its lot stiffer than before, so I guess time will tell if they hold up.  :)
I've still not solved all the rear suspension noise from the 2.2, I think the rear donuts needs to be changed next as over the same roads it's noisier than the 3.2, which also runs standard shocks.
Re: MaxTrac Shocks - A Review
« Reply #1 on: 19 September 2015, 21:43:40 »
Much better effort than the Bilstein mounts :y
Hopefully the shocks will serve you well...
« Reply #2 on: 21 September 2015, 18:07:50 »
OK, things may have changed since I last fitted Bilstein shocks to the arse of mine, but I had no issues with the mounting kit as far as I can recall. But that was probably 5 or more years ago...  ...and still going strong :y
