Author Topic: cambelt kits  (Read 3808 times)
pauls
  • By the sea minehead
    • Bmw x3
cambelt kits
« on: 29 September 2015, 10:32:10 »
I know this has been covered a thousand times but I cant find any upto date stuff.
Where the best place to by them also what make Gates,conti,vx
Diamond Black Geezer
    • & a silly coupe coming...
Re: cambelt kits
« Reply #1 on: 29 September 2015, 11:25:38 »
Amazon have a good one on at present (well, they did a couple of months back, at any rate) for about £50
Gates and Conti as good as each other. Anything marked 'SKF' is fine, as the original GM stuff is, too. There have been issues with a slight squeak emitting from a pulley rubbing on the belt on the Conti kits (wish I'd seen the posts before I bought my Conti kit  ::) ) I have a squeak myself, but haven't isolated it as being definitely the timing gear, yet.
Usual stuff, don't buy second hand, because you don#t know when it'll give up. (though my theory on this is the 4 yrs/40k rule is broken down in the following - mileage affects the pulleys, passage of time affects the rubber belt, but don't bet your engine on it, it's just a pet theory of mine :y)
Amazon, buy parts buy, euro car parts. Look out for discount codes. I bought a cambelt kit and added tot he order a brake hose for a few quid, which knocked £20 off the bill, by a 'spend over blahblah and get 20% off type of thing)
Other than that anything under £100 and you're on the money.  :y
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
Re: cambelt kits
« Reply #2 on: 29 September 2015, 13:35:05 »
Have a look in the classifieds, I`m selling my timing belt kit and alignment kit but will split if you like :y
pauls
    • Bmw x3
Re: cambelt kits
« Reply #3 on: 29 September 2015, 13:55:33 »
Re: cambelt kits
« Reply #4 on: 29 September 2015, 14:38:21 »
I would say so :y If the backing plate is in anyway different to yours, simply swap the new pullies onto your original plate :y
Re: cambelt kits
« Reply #5 on: 29 September 2015, 17:32:03 »
Absolutely nothing from ebay, amazon marketplace or euroshiteparts.  Far too many fakes floating around.
But a conti or gates belt with (genuine) SKF bearings should be fine (assuming not ordered from above).
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: cambelt kits
« Reply #6 on: 30 September 2015, 06:26:14 »
If it is for my ex irmscher then it would be due in 2016 I think. New engine 2008 and would have had another cam belt in 2012. I can check if necessary.
pauls
    • Bmw x3
Re: cambelt kits
« Reply #7 on: 30 September 2015, 09:50:58 »
Yes it is. just getting sorted only got 500miles left if done on mileage.
Re: cambelt kits
« Reply #8 on: 30 September 2015, 10:15:17 »
I understand maybe fakes on eBay...
But surely euro car parts aren't knocking out fake contitech kits!!?
Re: cambelt kits
« Reply #9 on: 30 September 2015, 10:46:46 »
Hear what you're saying, I think the concern with ECP is they have a history of sending out the wrong thing, that's all. So you may (and people have) receive a timing kit for a 2.0 Xantia or something. It's said/suspected Buypartsbuy are the same outfit, though. Pretty sure mine was from there, and arrived all fine and dandy.
If I were doing mine now, though I'd get it from amazon for the price.  :)
kevinp58
  • kent
    • 2002 3.2 elite
Re: cambelt kits
« Reply #10 on: 30 September 2015, 20:48:52 »
Buypartsby are all ways good contitech  :y
Re: cambelt kits
« Reply #11 on: 30 September 2015, 21:06:58 »
One of these?  :y
http://www.amazon.co.uk/cars/dp/B009ZQE0EM/ref=au_pf_sr_13?ie=UTF8&n=248877031&s=automotive&submodelId=8117
steve6367
Re: cambelt kits
« Reply #12 on: 01 October 2015, 08:24:58 »
I just got my 2 from VX - price not bad on TC and its not something I'm doing every day.
Re: cambelt kits
« Reply #13 on: 01 October 2015, 10:33:23 »
It wouldn't be the first time they have shifted low quality parts as branded. I certainly would not recommend them
Re: cambelt kits
« Reply #14 on: 01 October 2015, 12:32:25 »
Don't you believe it... Quick and easy way to double your margins... More likely to be on an individual store basis than across the board though :-\
