iPhone 6 battery life
Started by LFF64, 08 October 2015, 19:42:46
LFF64
Has anyone who has done the latest iPhone updates is9.02 I think it is found that the battery is not lasting as long as it did since the update
Can't speak for the phone, the pad is fine.
Mr.OmegaMan
Year old 6 Plus here is no where near as good as it once was when new but I've put this down to ware an tare of the battery itself, Plus i leave it on charge overnight which probably doesn't help.
As for iOS9 whatever version it's on now hasn't made a difference that I've personally noticed.
the alarming man
I have the upgrade phone is nearly a month old seems ok no difference tbh :y
LFF64
Just seems to be using the battery a lot quicker since last updated swmbo has the same phone and she updated hers too and she seems to think hers is Ok but her mate is saying the same as me I did an online check through apple and they are suggesting it is sent back to them to be checked I might give it a bit longer and if I still think it is not right I will drop in to the Apple Store in MK as we have to go over there next week and they can check it over
Broomies Mate
Check which apps are using battery......
Setings > Battery.
It'll show you which apps have used battery power in the last 24hours / 7 days depending on the tab you pick.  :y
plym ian
The other day i managed to get two days out of a single charge of my iphone 6 :o :o :o
Might return it to apple thats not right surly  ;D ;D ;D
Before you ask it was with minimal usesage ie not surfing the web, no apps open, no games playing ect
henryd
Quote from: plym ian on 09 October 2015, 09:03:11
So switched off then ??? :o :o ;)
other rides
brendan1983
I've found the battery life better on mine since updating...
At the end of the day I usually have about 25-30% left - previously I was having to put it on charge after work.
2003 CDX & Yamaha Thunderace
My 6s seems Ok with IOS9 (currently 9.02).  I can get 2 or 3 days out of it with the use I give it.
My old 5 on IOS8.4 something is shockingly bad, needs charging at least daily.  I suspect the 1000 or so charge cycles have hit the battry hard.
Quote from: TheBoy on 09 October 2015, 16:32:18
6s?? Finally joined the modern age? :-X ::)
Quote from: Lazydocker on 09 October 2015, 18:49:07
Got that fast after launch too  :o
Secret fan boy me things  :-X  ;D ;D ;D
the alarming man
my one last two days on every charge...no game playing etc but with 5-6 calls every day
LFF64
It was the Bluetooth using the battery turned it off last night and battery is still at 68 % since last night before it was turned off the battery was down to about 50%  before lunch time
Quote from: tunnie on 09 October 2015, 21:35:04
Not very secret to be fair :-X :D
