Author Topic: Fencing - Surrey/Hamshire Area  (Read 6258 times)
« on: 10 October 2015, 15:22:29 »
Anyone had any fencing done in the Surrey area recently? Done Google/Check-a-trade ect, but wondering if any one here has had work done recently they were happy with?
Thanks  :y
Re: Fencing - Surrey/Hamshire Area
« Reply #1 on: 10 October 2015, 16:31:55 »
Had a fence replaced by an outfit in Yately recently. Yarely fencing iirc. Turned up as arranged and did a decent job.
Will dig out details later. Currently travelling.
« Reply #2 on: 10 October 2015, 17:56:34 »
Cheers Kevin  :y
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #3 on: 10 October 2015, 18:22:25 »
Not that tricky to do yourself.  Extended mine 16' up the side of the house including gate and was only 8mm out on one of the posts.  Took 1 weekend.
« Reply #4 on: 10 October 2015, 18:42:07 »
Only thing I can add to this is don't scrimp on the panels :y
PS lattice panels don't blow away in storms...  :D
« Reply #5 on: 10 October 2015, 19:59:29 »
The quotes I've got so far, does make me want to do it myself. Hummm fancy a job as a supervisor, payment with beer tokens? If I went DIY?  :D
The ground is a shit to dig though, full of rubble  :(
The builders of our Estate used the thinnest panels known to man, I've seen A4 paper that's been thicker  ;D
Kate
  • Cornwall
    • Drives people mad
« Reply #6 on: 10 October 2015, 20:05:02 »
I can help if you need it. I've done some fencing recently. :y
I'm free all day tomorrow.
« Reply #7 on: 10 October 2015, 20:08:27 »
Did you do it all yourself? We are out tomorrow, thanks for the offer  :y
ted_one
« Reply #8 on: 10 October 2015, 20:12:45 »
Extended my fence on my own land and ended up with a court order to take it down,all now on Ebay....local council=corrupt tossers!! >:(
Kate
  • Cornwall
    • Drives people mad
« Reply #9 on: 10 October 2015, 21:06:09 »
Yes but it was just two fence panels and a gate. I've done fencing before though using posts and postcrete etc.
Gaffers
« Reply #10 on: 11 October 2015, 15:59:32 »
i used my sds drill with the chisel attachment to get through the tqrmac and then to loosen the made ground underneath.
Made it easy work.
If you need a hand let me know :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #11 on: 12 October 2015, 11:07:43 »
Get yerself one o' these mothers Tunnie lad:
Used mine to dig-out a flag pole base at the Welland Steam Rally when others had failed miserably.
18" hole sorted in around 20 minutes! :o
Available here: http://www.screwfix.com/p/roughneck-17lb-post-hole-digger/62496
« Last Edit: 12 October 2015, 11:09:38 by Seth »
« Reply #12 on: 12 October 2015, 11:22:38 »
You are probably looking at about £80-£90 per panel fitted for concrete posts and gravel boards, which is probably a good plan.
« Reply #13 on: 12 October 2015, 11:49:45 »
Thanks Chaps m
Seth that looks like it could do the job  :) :y
« Reply #14 on: 12 October 2015, 12:09:41 »
These chaps?
https://www.yell.com/biz/yateleyfencing-gmail-com-yateley-7660116/
