Washing machine breakdown
Started by powerslinky, 21 October 2015, 12:10:13
powerslinky
This could be quite a long post but  . . thought I would post this up  as never heard of this happening before .
Have a 3 -4 year old hotpoint WMF940 washing machine . It has run faultlessly since new . Up until now  ::)
It did not finish it's cycle & F-05 was the code on the display . I had a search around the manual & online  & this seemed to point to a pump problem .
I removed the machine from the utility room , to outside the house , removed the filter & found 3 coins  :y
Replaced filter & thought I would just run a programme by connecting the water supply & power outdide where it was sitting.
Bear in mind machine was in mid cycle ,  & as soon as I switched on the power the machine display would light , fault code had gone,but after a second,  the main RCD tripped in my consumer unit :-\ .  The MCB for the utility circuit did not  :-\.
Found out through researching that if the RCD trips , it is usually an earth fault or direct short :o
So started by disconnecting the pump feed , still the same , almost instant RCD trip . worked around the machine disconnecting  items , door switch, circuit board etc.  but still the same , RCD tripping .
Ended up back at where the power comes into the machine & there is some sort of power supply there & the mains goes into this & there is a L N E coming out which supplies everything in the machine . So disconnected this outward supply & switched on at the socket  . . . . still tripped the RCD :o :o :o
Disconnected the inward supply wires L N E . . . . so all we had was a plug & length of mains cable  . .  it still tripped the RCD :o :o :o :o
So  . . . ok it must be a mains lead fault  I  thinks  . . . so tested cable for shorts or breakage  . . but nothing showing  ::)
So cut off moulded 13 amp plug & fitted a new plug  . . . . BINGO  . . .  all working fine .
Have never known a factory fitted moulded plug to be faulty before .  So question is  . . . what caused it to  fail ?
Seems weird as the machine was still on & lit up showing the fault code when we first noticed it had not finished it's cycle
Any ideas ?
Matchless
Take the fuse out of the moulded plug and have a good look at the fuse and fuse clips for signs of overheating, also look for carbon or discolouration of the plastic within the fuse compartment.
Check for any signs of overheating or discolouration of the wall socket as well - a loose or weak contact in the socket can cause the plug to overheat.
We replace a reasonable number of mains leads each year due to similar faults on high-powered medical devices, the fuses and contact clips heat up in normal use, the plastics begin to soften and degrade, eventually becoming sufficiently conductive to trip an RCD. We inspect all mains leads annually and carry out an insulation test to weed out failing leads before they cause a problem - even finding faults with brand-new leads occasionally.
powerslinky
Quote from: Matchless on 21 October 2015, 14:12:24
Thanks for that  . . . I will disect the old plug & investigate :y
Another possibility is that the plug suffered water ingress while you were working on the machine, perhaps?
powerslinky
Quote from: Kevin Wood on 21 October 2015, 15:58:49
ah ..good point Kevin  . . could well have done .
I am trying to find where I have put the old moulded plug so I can inspect it  :-[
baggers
Or made in china  ::)
Some of the wiring that comes out of China is a disgrace.
baggers
Sometimes if the brushes get low they can cause the program to fall short and in some cases cause tripping and there are occasions were it can track back and damage the PCB.
Ever Ready
Had a similar problem this morning with an electronic fly killer, it tripped the breaker twice, unplugged the power cord and tested it again, tripped the breaker again
Turns out water had dripped onto the cable connector where it enters the unit and tracked across the live,neutral & earth
New one ordered for next week :)
An ounce of experience is worth more than a pound of enthusiasm.
Quote from: Ever Ready on 24 October 2015, 20:39:10
It snowed in Scotland today, I'd leave it till next year, unless the flies up there are much hardier than down here.
