Sachs rear coil springs ?
Started by EMD, 26 October 2015, 12:13:08
EMD
Anyone ever used Sachs rear coil springs and are they any good  :-\ If not what's recommended ?
Omegatitis
amba
Had a set fitted for the past 6 weeks/1500 miles and so far no issues.
I have a very full boot most of the time and seems to hold the car well.Didnt repl;ace the shocks at the same time,despite having a set of B,4,s in the stock cupboard so may replace them in next couple of weeks as think set on where done when springs were last replaced according to past service record in 2009 so imagine they are getting tired.
Reading Tunnie,s issues with them though may hold off
EMD
Just that on ecp they are selling the springs at discount from £460 reduced to £35 each . Got a annoying creak/knock when turning or going over uneven road surfaces . Needs investigating but thought these springs were good value .
Omegatitis
amba
At that price they are cheaper than the Sachs I got..think mine were around the £80 for the pair.
Almost worth buying several sets at that price and selling on with small profit to recoup your original spend for your set  :y
Webby the Bear
Sachs fitted to mine about 4 years ago now. Still going strong. Only complaint is they're a bit floaty. But otherwise great
RIP Paul Lovejoy
EMD
Quote from: amba on 26 October 2015, 12:46:20
Shhhhh  ;D
Quote from: Webby the Bear on 26 October 2015, 12:50:10
Hmm maybe just me but i think the cdx is a bit floaty , more than the elite  :-\ Im sure my springs are originals from factory so would prefer a more stiffer spring .
Omegatitis
Webby the Bear
RIP Paul Lovejoy
Sasch/Boge all good for the rear  :y
amba
Think I will end up fitting new shocks too ,as have set in storage.
My main concern reading past threads is the actual mounting set.B,4s as supplied seem to be poor quality than the GM that are fitted to an old set of SL shocks I also have but see the 2 fixing sets arent compatable unless you fir GM Estate .
EMD
#9
Maybe MV springs for me then  :-\
Or just buy an MV6 , could work out cheaper . New i should have kept the mv  ::)
Quote from: amba on 26 October 2015, 13:06:04
Ecp have KYB rear shocks for £34
Omegatitis
amba
Fair price but wonder what the quality of the top rubber mounting set would be like.
Seems that supplied with B4,s is poor and requires further expense buy Estate fixing set from GM so probably by the time all said and done just buy from GM as hopefully that will include the fixing set
EMD
Quote from: amba on 26 October 2015, 13:15:29
Ah i see so not the shock itself , the rubber mounting  :(
Omegatitis
Diamond Black Geezer
Just my 'twopenneth'... fitted MV6 springs to my V6, and though very happy with the handling etc.. they did raise the ride height by an inch or two.  :y
ie: the originals were definitely correct, not Elite SL ones, or anything, but most likely the originals, therefore clearly sagged and worn. The MV6 replacement ones came off a much younger lower mileage car. You may find that your Sachs ones will tighten up the ride nicely, in spite of them being 'the same' as the ones you're replacing. Sachs have a good reputation, and unless anyone happens to the scrapping a FL MV6 at the mo, they're pretty hard to get hold of.
Personally, given how easy they are to replace, I'd be getting these Sachs, and keeping an eye out for MV6s; which after all, a good set may not turn up for 6 months.
Quote from: EMD on 26 October 2015, 13:09:26
I have a set of KYB rear shocks on mine that I fitted just over 12 months and about 15000 miles ago and they're fine.  The rubber top mounts did seem a little smaller than what I removed, but I've had no issues.  :y  Not worth dicking about and spending extra on GM mounts in my opinion.  :)
EMD
Quote from: Sir Tigger on 26 October 2015, 13:33:29
Good to know so mite order a set of those then .
Dbg : i thought mv springs lowered the ride height  ??? Didnt realise the mv springs were in short supply so mite go ahead with the sachs then .
Omegatitis
