Author Topic: emmisions warning light  (Read 3696 times)
hoj
  • BURY
« on: 29 October 2015, 21:49:21 »
The e w l has come on
I take it this is a fault with the lambda sensor? Am I right?
If so if I don't get a new sensor fitted what will happen?
Car seems to be running fine
3.2 Elite in Oyster
Re: emmisions warning light
« Reply #1 on: 29 October 2015, 21:54:30 »
Engine etc... ::)
« Reply #2 on: 29 October 2015, 22:28:25 »
Hang on, let me get out the crystal ball.
Soon know what engine  ::)  ;D
hoj
  • BURY
« Reply #3 on: 30 October 2015, 07:37:06 »
It's a 3.2 engine
Does that matter?
3.2 Elite in Oyster
« Reply #4 on: 30 October 2015, 07:48:47 »
Matters a lot....
On a 3.2 the emissions light tends to come on with 320 / 340 codes as the precats lose efficiency.
Nothing to do with the sensors they are doing the job perfectly.
The cure, if it is this, is to move the lambda sensors from in front of the main cat to behind it, Im sure there is a guide explaining whats required.
If you can do the pedal trick and confirm the codes....
« Last Edit: 30 October 2015, 07:51:13 by Jimbob »
« Reply #5 on: 30 October 2015, 07:49:32 »
« Reply #6 on: 30 October 2015, 10:02:16 »
0420/0430 ::)
Can do pedal trick to verify the codes and then suitable advice can be given :y
« Reply #7 on: 30 October 2015, 10:06:48 »
...and if it was not a 3.2 say a 2.2 or something else, could be a very different issue. Hence always good to know exact details.
Worth updating your profile with engine/spec details  :y
omega man 69
  • France
« Reply #8 on: 13 November 2015, 18:42:34 »
Hello can anyone tell me what is the pedal trick???????? :-\/ also what would cause my 2.2 omega automatic estate gear box to suddenly stop driving in auto and can only be driven in manual/car is 2001/think I will have to come back to the UK/I am an old lady and I love my 2.2 estate but no use to me in manual /can anyone tell me what might be wrong/have just paid another 72 Euros bringing total up to over 900 Euros/I have been told /List
1 MAF changed no difference
2 Lambda sensors changed no difference
3/2 auto gearboxes changed no difference
4/Have been told by Opel it needs a new Calculator????
Anyone speak French can tell me what this might be????
OH! and the price is 1300 Euros???? is it possible whatever this part is
can be sourced second hand??????
will be grateful for any help (have been told it might be an Engine Management ECU????
« Reply #9 on: 13 November 2015, 19:07:41 »
Hello can anyone tell me what is the pedal trick???????? :-\/ ....
Voila http://www.omegaowners.com/forum/index.php?topic=90581.0
unfortunately that's the limit of my French, and the pedal trick doesn't work on a 2.2.
Failing cam sensors seems to do trigger all sorts of daft faults on a 2.2  :-\
« Reply #10 on: 13 November 2015, 19:49:41 »
All as per pm sent... one dodgy replacement gearbox is unlucky, two is almost certainly a cam sensor ::)
Ou habitez vous? Il y a un ami ici qui travail en Lyon (Monsieur Guffer), et un autre qu'a famile qui habitent pret de Bordeaux, je pense (Nick W).
