Author Topic: WANTED - AR25 Wiring Loom  (Read 3171 times)
steve6367
« on: 05 November 2015, 09:59:58 »
From inside the large sump - I've broken a clip on mine   :(
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: WANTED - AR25 Wiring Loom
« Reply #1 on: 05 November 2015, 10:46:32 »
Did you not like the idea of getting a Ar35 box and putting it straight in  :-\
steve6367
« Reply #2 on: 05 November 2015, 23:01:06 »
I thought removing / installing the box was beyond my DIY skill so was just going for the solenoid change. Unfortunately I think found thrust washer in the small dump so was forced to remove the box anyway! It's been a good learning experience so far, but happy to admit the forum wisdom was correct and a swap would have been quicker!  :-\
steve6367
« Reply #3 on: 05 November 2015, 23:01:44 »
I thought removing / installing the box was beyond my DIY skill so was just going for the solenoid change. Unfortunately I found thrust washer in the small dump so was forced to remove the box anyway! It's been a good learning experience so far, but happy to admit the forum wisdom was correct and a swap would have been quicker!  :-\
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #4 on: 06 November 2015, 11:51:46 »
Don't worry  :)
Priority 1 is always getting your car back on the road. Sometimes that can involve getting a replacement component as a spare, which you can work on refurbing at your leisure in the shed etc.. meanwhile a 'gets me back on the road' thing can be fitted. Tackling the repair of something critical like an alternator, exhaust, gearbox, that if not mended for work tomorrow morning means a taxi in/bus/beg a lift can cause more aggro than it's worth.   :y
Hope you're sorted soon  :) Plenty of AR25s on here as possible spares donors.
steve6367
« Reply #5 on: 06 November 2015, 15:04:08 »
Don't worry  :)
Thank you, its not a disaster - just using the saloon currently. Other than the fact its not LPG that's ok  :y
