How to
Started by EMD, 07 November 2015, 11:42:10
EMD
Whats the best stuff to use to fix my aquired window
spoilers/wind deflectors things with  :-\
Omegatitis
EMD
These type of things :
Omegatitis
Is that a Frontera?
Quote from: Doctor Opti on 07 November 2015, 13:28:07
Is that a Frontera?
The Land Rover badge would suggest not  ;)
Freelander 1
Quote from: tunnie on 07 November 2015, 13:31:40
Is that a Frontera?
Freelander 1
So it is........smartarse. ;) ;D
BazaJT
I suppose it all rather depends on whether you're figuring on removing them again at some future date.Would some kind of strong double sided tape be strong enough to hold them on?Or Tiger seal/Sikaflex possibly?
Not to mention where you actually stick them... only the rubber trim around the top of Omega doors ::)
EMD
#7
I presumed they pushed into the door rubber but i will check as they mite have to stick on the outside of the door  :-\
Just checked them and they do need to be fixed into the rubber , looks like there is some sort of sealant residue from previous fixing still left on them so need to remove all that first ..
Omegatitis
minifreek
I can only presume this is for an Omega....?
I have the Heko's installed and stuck them on with Gorilla superglue, much better than Loctite Superglue as the Gorilla stuff doesn't desolve in water :y
They won't just stay in with a push like the old one's used to with the clips...
D.I.L.L.I.G.A.F...
