Pages: 1 [2] 3  All   Go Down
Author Topic: whats this likely to be then chaps ?  (Read 10119 times)
Re: whats this likely to be then chaps ?
« Reply #15 on: 13 November 2015, 20:17:53 »
So if it were you then Harris, would you just do the cam sensor anyway.
And presumably I need a genuine VX one.
And could you do it for me :)
Personally I would. Yes genuine only, that you physically have to collect. Go Vauxhall have a trade warehouse over in Burgess Hill, so would start there.
Part number should be 9012039, but double check with them against the reg/chassis number before ordering :y
As for fitting, should be fine, as looking like limited overtime in December... so hypothetically I have half the month off ::)
  • Auckland
    • Mazda MPV
« Reply #16 on: 13 November 2015, 20:32:23 »
If I understand the situation in a right way I had something similar with my AR 25 a year ago. In my case I had to change the "electronic box" in left side of the gear box connected to the selector shaft which goes into the box. System did not know anymore which gear was selected. Had to select manually gears. I opened the box afterwards and realized that the sliding connectors were worn out, remember 300- 400 euro was the price of the spare part. This case have been discussed here, I did not find it yet. Can this be the case?
The selector switch can cause problems - this guide Auto gearbox selector switch removal and cleaning has some useful pictures.
With the code reader I have I can see which position the ECU thinks the selector switch is in which should help in diagnosis.
Odds are that it is the cam sensor though ;)
« Last Edit: 13 November 2015, 20:33:54 by Andy H »
« Reply #17 on: 13 November 2015, 20:37:27 »
When I touch the automatic gear selector in P position all the lights or leds PRND21 goes on
OP has a different problem to yours. All his LEDs behave normally
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #18 on: 13 November 2015, 20:39:49 »
Do you borrow a used known working proper 2.2 cam sensor
« Reply #19 on: 13 November 2015, 20:41:34 »
Not for a 2.2. Correct number is 90520850
« Reply #20 on: 13 November 2015, 21:14:35 »
Thanks Rob :y
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #21 on: 13 November 2015, 21:36:25 »
what is this 'limp mode' you all talk about? does it just apply to autos? (bet it does). never had one or it myself :).
« Reply #22 on: 13 November 2015, 21:42:25 »
the engine goes into a get you to the nearest garage/home as best as it can mode ......
No .... it's the engine that's limping, not the gearbox
you should try one ........ 3 pedals bad ..... 2 pedals good  ::) ::)
« Reply #23 on: 13 November 2015, 21:49:49 »
Bahpishhumbug ::)
« Reply #24 on: 13 November 2015, 21:59:58 »
Bahpishhumbug ::)
All my replies or justthe last bit .......  ::) ::)
« Reply #25 on: 13 November 2015, 22:02:23 »
Bahpishhumbug ::)
He's "Bahpishhumbug"ing his own inability to drive a "proper" luxury saloon .... one where the number of pedals equals the number of feet ..  :)
« Reply #26 on: 13 November 2015, 22:11:56 »
I thought better of Al ...... I didn't realise he was one of the 'I want to be in control' boys  ;D ;D
As you say .... 2 feet = 2 pedals! what more could you ever need  :y :y
amazonian
  • upper beeding. west sussex
    • 03 2.2 CDX auto estate
« Reply #27 on: 13 November 2015, 23:47:39 »
Thanks lads for all the input, If I can get codes read I will, but will probably get new cam sensor anyway and get Harris K Telemacher to bung it on when he can.
« Reply #28 on: 14 November 2015, 03:22:20 »
You mean my ability to use two feet to do more than one thing ;D
« Reply #29 on: 14 November 2015, 03:22:52 »
Pages: 1 [2] 3  All   Go Up
Page created in 0.014 seconds with 22 queries.
