New Generation Sky Box Launch
Started by tunnie, 16 November 2015, 12:23:08
So on Wednesday the 'Next Gen' Sky boxes will be launched, I know very little about them. Sadly my pass does not let me into the building where it's all being done.  :(
But rumours suggest maybe 8 tuners, 4k was big rumour, I've not heard much on this, but it will be some time before decent content would be broadcast in 4k anyway.
Recordings will be much more cloud based, rather than just on set up box.
So watch this space  :)
Interesting. But cloud based recordings can be an issue if slow broadband speeds.
Typical this has now come shortly after I have upgraded to 2TB box ::) ::)
Mind you, I'm reliably informed that the older HD boxes will take a 2TB drive and the 2TB box will recognise up to 5TB :-X ;)
Quote from: Lazydocker on 16 November 2015, 16:06:52
..and also if you'd connect uncle Rupert's box to your network only over your dead body. ::)
korum
I can't imagine 8 tuners to be real especially with 4k as I bet there isn't enough bandwidth to cope with that let alone an lnb to fit 8/16/24 connections.
cloud based recording could mean that you would be able to now watch your recordings via the sky go app which would be nice.
zirk
So there's hope for my little NowTV box after all.
Quote from: zirk on 16 November 2015, 20:05:21
Other plans for that, of which I do know  :-X :-X
Quote from: korum on 16 November 2015, 19:41:32
Later point. You maybe right  ;)  :-X
zirk
Quote from: tunnie on 16 November 2015, 20:53:17
Put some proper Roku Apps on it.  ;)
Quote from: zirk on 16 November 2015, 21:09:54
You can side load any Roku apps you want already?
Just pop it in Dev mode :)
zirk
Quote from: tunnie on 16 November 2015, 21:29:47
Yea, but only do able for 1 App (most use it for Plex) then its dusted, would be nice to load some more from the Roku Store or push Win Home Media, Mobile in to it, etc.  :)
Which apps? Just source them elsewhere, OK can only install one at a time. You know there is black box out now with Ethernet socket?
zirk
Quote from: tunnie on 16 November 2015, 21:47:23
No, I didn't, is that the 1080p one that Ive heard about.
zirk
Quote from: tunnie on 16 November 2015, 21:58:15
No, where have you read about 1080?
Its basically Roku3.....
http://www.engadget.com/2015/08/04/sky-new-now-tv/
Can't remember now, someone told me 1080p was in the pipeline for the box, why is it not the case.
Given Sky don't broadcast any 1080p content yet it would put the Now TV box ahead of the 'main' (currently) service?
The only streaming box I know of with 1080p is the Apple TV one.
