Author Topic: auto selector switch  (Read 7699 times)
pauls
  • By the sea minehead
    • Bmw x3
« on: 16 November 2015, 14:19:53 »
Some times when putting the car into park it does not click in. Also when turning the ignition back on the "foot on Brake test" thing on the cid doesnt come up it shows the radio station etc straight away.
 The lights all seem to be in the right postion while in drive,reverse etc.
Would this be the selector switch or something else.
Diamond Black Geezer
    • & a silly coupe coming...
Re: auto selector switch
« Reply #1 on: 16 November 2015, 15:46:52 »
If it were me I'd be looking at the switch (the part on the side of the gearbox, underneath the car) which often gets oil and rubbish in them, which can cause issues. Hopefully comeone can offer you something else to check first, which isn't quite such a mucky job?!
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #2 on: 16 November 2015, 15:57:30 »
My 2.6 sometimes does the opposite - I put my foot on the foot brake to take it out of 'park', but I can't hear the 'click' from the switch and it won't come out of 'park'. I have to press the foot brake a couple of times until the 'click' is heard before I can get it out of park, then it's all ok. Doesn't happen all the time, but until I know it's definitely the auto selector switch, and then sort it, I'll probably get stuck somewhere in 'park' at the most in opportune time.....
« Reply #3 on: 16 November 2015, 16:02:41 »
Easy enough to release. Yellow lever under gearstick gaiter
johnnydog
  • Lancashire
« Reply #4 on: 16 November 2015, 16:10:09 »
That's handy to know, thanks.
Going back to my own issue of occasionally getting stuck in park, would the symptoms I've given point to the auto selector switch being the problem?
« Reply #5 on: 16 November 2015, 16:46:44 »
I would check the brake light switch. This will affect both the locking of the gear selector in "Park" and the brake light test at startup. My guess is that your brake lights are permanently on!
johnnydog
  • Lancashire
« Reply #6 on: 16 November 2015, 17:03:11 »
An easy check to start off with then, but won't be able to do it until Weds. The brake light switch sounds like a bit of a back breaker to change.....
pauls
    • Bmw x3
« Reply #7 on: 16 November 2015, 17:42:47 »
How do you check if this is working correctly..
« Reply #8 on: 16 November 2015, 18:11:13 »
Obviously brake lights working, but theings like not being able to get the car out of Park & whether cruise control will engage
« Reply #9 on: 16 November 2015, 18:14:45 »
How you gonna check if cruise is working if you're stuck in park? Eh?  ;D
« Reply #10 on: 16 November 2015, 18:41:42 »
There's always one ........  :P :P  ;)
« Reply #11 on: 16 November 2015, 18:44:56 »
My thoughts exactly.
pauls
    • Bmw x3
« Reply #12 on: 02 December 2015, 12:33:12 »
Update on this.. Had this replaced with brand new one from dealers. It worked for a day and now cid just goes straight on radio station etc.
Any ideas please
« Reply #13 on: 02 December 2015, 13:04:13 »
Two questions
1) Are the brake lights always on or flickering?
2) If you grab hold of the brake pedal, is there any play or free movement in it?
pauls
    • Bmw x3
« Reply #14 on: 02 December 2015, 13:43:13 »
Two questions
answer 1. Dont believe so.
Answer 2. There is some movement but I wouldnt say a lot.
