Author Topic: Handbrake q...  (Read 8808 times)
Diamond Black Geezer
    • & a silly coupe coming...
Re: Handbrake q...
« Reply #15 on: 18 November 2015, 10:58:51 »
Ah, fair dos... you run Monaro rear calipers, yes?
Re: Handbrake q...
« Reply #16 on: 18 November 2015, 11:39:24 »
Do now, following the debacle in obtaining, or not, new vented calipers...
Re: Handbrake q...
« Reply #17 on: 18 November 2015, 14:40:17 »
9156405 apparently... Pair on order :y
EMD
  • Noofhampton
    • 95t
Re: Handbrake q...
« Reply #18 on: 18 November 2015, 16:29:23 »
They are handed left and right, left hand is sod to get off and I usually cut it off to save time.
They usually fall off  ;D Not too bad putting them back on if you use a small pair of vice grips .
Make sure gloves are worn to prevent hand mutilation when you slip  ::)
Omegatitis
  • Online Online
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Handbrake q...
« Reply #19 on: 18 November 2015, 16:36:40 »
Anyone fiddling about with brake springs, including the ones inside drums should get one of these  http://sealey.co.uk/PLPageBuilder.asp?gotonode=ViewProduct&method=mViewProduct&productid=12583&promotionid=74630&promotiontitleid=440  It's worth the retail price listed there, but you can get them cheaper.
EMD
  • Noofhampton
    • 95t
Re: Handbrake q...
« Reply #20 on: 18 November 2015, 16:39:28 »
Hm could quite easily be made  :) Got a few spare tent pegs here .
Omegatitis
  • Online Online
  • Chatham, Kent
Re: Handbrake q...
« Reply #21 on: 18 November 2015, 16:43:58 »
It's heat treated so that the very fine hook(the key to its usefulness) stays a hook and doesn't straighten out. Unlike a tent peg or the welding rod I've used in the past. I paid less than a fiver for mine, and rarely use anything else on small springs. Saves a lot of swearing, unlike most of the other brake tools I have.
Re: Handbrake q...
« Reply #22 on: 19 November 2015, 09:44:28 »
The usual method I use has been levering in a screwdriver, and pinging it out, with the associated parts flying in all directions, some never to be found again. This 'hook' of which you speak does have a certain appeal  :)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Handbrake q...
« Reply #23 on: 19 November 2015, 19:04:27 »
I put some wire behind the spring, pull the ends towards me, twist them together, put a screwdriver through my loop, and pull. What is tricky is unhooking the spring from the brake lever to release the cable on the LHS. After a minute trying I cut it off.
Shallow Al
  • Lymington, Hampshire.
    • 3.0 Litre Elite.
Re: Handbrake q...
« Reply #24 on: 20 November 2015, 23:43:15 »
Looks like it might be useful to get radios out....delicately of course ??? ???
I used to know everything. Then I got married.
