Author Topic: irmscher exhaust?  (Read 3489 times)
Sir Sideways
  • Sideways in Staffordshire
    • PFL 3.0 Auto Elite Estate
irmscher exhaust?
« on: 22 November 2015, 18:15:10 »
Did the omega come with an option for a stainless exhaust system (irmscher or other).
Regards
Jim
Re: irmscher exhaust?
« Reply #1 on: 22 November 2015, 18:18:42 »
Regards
Jim
Not that I`m aware of :-\
serek
  • huntingdon
    • 3.2 mv6
« Reply #2 on: 22 November 2015, 18:20:18 »
back box only
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #3 on: 22 November 2015, 19:18:20 »
Jetex system is stainless, and still available from demon twerps,and is a proper twin box system as per the standard system hence its £600 price,good fit too. 8)
Hoof'land storeman.
Sir Sideways
« Reply #4 on: 22 November 2015, 19:18:55 »
Ok thanks, looking to get a stainless built in the future and want it to be as close to standard as poss. Also undeceided wether to go single or twin exit.
« Reply #5 on: 22 November 2015, 20:43:50 »
Wherever they tell you, you need to keep twin pipe and mid boxes, otherwise there's likely to be a loss in power ;)
Sir Sideways
« Reply #6 on: 22 November 2015, 21:08:23 »
Yep will do. Think ill probably stick to the single side twin exit 65mm. I dont fancy the look of 4 pipesat all - too chavy.
Sir Sideways
« Reply #7 on: 22 November 2015, 21:15:35 »
Just remembered, on my last omega, it went to 1 pipe after the middle box. Iirc it was 75 -80mm pipe to make up for 2 pipes. Didnt loose any power.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #8 on: 23 November 2015, 14:09:33 »
If your going for a custom job, I wouldn't rule out Long life Exhausts, had a few SS Exhausts by them now, while they can build to OEM spec they can also tinker with it to your own design for not much more money.  ;)
Sir Sideways
« Reply #9 on: 23 November 2015, 14:13:51 »
Powerflow is my local or SS Silencers. Ill have a look round to see whos nearby to staffordshire
zirk
  • Epping Forest
« Reply #10 on: 23 November 2015, 14:28:13 »
Not near you but LL at Bristol have made up a full system to include a Left / Right fear to suit the Irmscher rear bumper, they may still have the plans, template.
Sir Sideways
« Reply #11 on: 23 November 2015, 14:43:44 »
Bit fa away but id also need a Irmscher bodykit  first lol.
zirk
  • Epping Forest
« Reply #12 on: 23 November 2015, 15:13:06 »
Good luck with that one.
Probably better to put some money aside and buy a whole car with it all on if I'm honest, as or if one does come up.
« Reply #13 on: 23 November 2015, 17:34:03 »
There was no stainless option from the factory. Irmscher was the official I-Line styling provider, but this was all aftermarket, not factory fit.
Irmscher offered 2 stainless backbox options, but not a complete exhaust (as they are predominantly a styling company)
Sir Sideways
« Reply #14 on: 23 November 2015, 19:07:48 »
The main reason for the post was to see what irmscher tailpipes look like so I can replicate them. I'm just gonna go for the single exit twin slash 65(ish)mm.
Thanks for the replys
