Range Rover P38
Started by EMD, 25 November 2015, 13:09:34
EMD
 Front doors on central locking as stopped working on 4.6 V8 Vogue , locks with key :( Expensive to fix or cheap and cheerful  :-\
Omegatitis
Cheap and cheerful fix for a rangie? Dream on.  ;D
Crazycarzowner
Either replace them for new ones @ about £150 each or remove them & clean them.
The motors are simple things really but the connections to the motors get dirty and need cleaning, as does the commutator and brushes. This involves removing the latch mechanism from the doors, taking the cover off to get to the motor, removing it, opening it up, cleaning it and putting it back together.
Have both front doors stopped working and if they have do they both lock with the key in the drivers door?
EMD
Quote from: Elite Pete on 25 November 2015, 17:43:05
Both front doors not working with the fob but lock manually  ;)
Omegatitis
Quote from: EMD on 25 November 2015, 19:58:28
No...what Pete wanted to know, for a reason obviously, was when you lock the drivers door with the key, does the passenger door lock as well. Because I doubt both motors would go together
EMD
Quote from: STEMO on 25 November 2015, 20:05:24
Fraid not  :(
Omegatitis
I've just bought a couple of motors at £75 each and that's at cost  :'( but there's a bloke on Landyzone that reconditions them :y
EMD
Quote from: Elite Pete on 26 November 2015, 15:42:04
Thanks pete i didnt know that site existed so will have a good read on there  :)
Omegatitis
Quote from: EMD on 26 November 2015, 15:44:41
It's not quite as good as this place but there's loads of good info :y
